Friction on an accelerating train
The discussion revolves around calculating the minimum coefficient of static friction required for a person to avoid sliding on an accelerating train. The problem is framed in terms of forces acting on the person, specifically the frictional force and the force due to the train's acceleration. Participants clarify that the only relevant force is the friction from the train's floor, not a "force of the train." The correct approach involves using an inertial frame of reference to relate the forces, ultimately confirming that the coefficient of static friction is 0.2. The conversation emphasizes the importance of understanding forces in physics problems to avoid confusion.
beetlegauss
I have a question for homework, and this is a high school physics class. The question reads:
Suppose that you are standing on a train accelerating at 2.0m/s^2. What minimum coefficient of static friction must exist between your feet and the floor if you are not to slide?
I've drawn a free body diagram, and motion in the Y dimension doesn't really matter.
In the X dimension, I THINK there are 2 forces: Force of the train, and Force of friction. What I've come up with is this:
Fnetx=0 (Since I'm not accelerating in relation to the train itself. I'm hoping this assumption is right, or everything else is wrong.)
Fnetx=Ft-Ff
Ft=Ff
Ff=9.8mu, and Ft=2m (This is where I'm getting sketchy. Is the force of the train on the person the same as acceleration x the persons mass?)
9.8m/2m=u
u=.2
I'm basically posting to verify my answer, since I'm not entirely sure if the route I took to get to it was right. Thanks for reading!
Looks good to me except this bit;
9.8m/2m=u
It should read; 2m/9.8m , however, your final answer is correct so I assume its a typo.
Oh yeah, thanks. So the coefficient is .2, and the force on the person is his mass times the trains acceleration, then?
I don't really understand your reasoning. What's Ft?
Rather than try to describe things from the accelerated frame of the train, simply describe it from the frame of the tracks. Answer these questions:
(1) For you not to slide, what must your acceleration be?
(2) What force provides that acceleration? How does it relate to your weight and the coefficient of static friction?
(3) Use that to deduce the minimum coefficient of static friction needed.
Ft is, um, Force of the train. I didn't know what else to label it as. The only thing I was confused about is whether or not the Force of the train on me is it's acceleration times my mass.
There's no such thing as "force of the train". The only force acting on you (horizontally, at least) is the friction from the floor of the train.
(You can view things from an accelerating frame of reference, such as the train. But that introduces so-called "fictitious" forces that are artifacts of using such a non-inertial viewpoint. Things end up being close to what you did, but for very different reasons. I suggest forgetting about such advanced methods and sticking to real forces for now.)
What Doc Al is saying, is that you can also consider this problem from an inertial reference frame. This could be someone stood at the side of the tracks watching you accelerate past at 2m/s2. Now, the force required to accelerate you at this rate is twice your mass, yes? Now, this force is provided by friction between the floor of the train and your shoes; so we can say that 2m = mg\mu, which is equivalent to your expression and you will obtain the same answer.
There is nothing wrong with solving problems using non-inertial (accelerating) reference frame provided you understand the implications. In general, it is always advisable to use inertial (non-accelerating) frame of reference to avoid confusion.
Edit: Looks like Doc Al's got it :wink:
Yes, actually, I did the problem two different ways, both of which ended up with the same answer. The first way, which i thought was wrong, was this.
Ff=2m (so now I'm accelerating, and there is no force-of-train)
9.8mu=2m
u=2m/9.8m
u still equals .2
Alright, coolio, I think I've got both of them now. lol, thank you both.
9.8mu=2m
u=2m/9.8m
u still equals .2
Nothing wrong with that. And no need for any mysterious "force of train"!:wink:
One thing to realize is that \mu mg is the maximum value of static friction. Using that, like you correctly did, gives you the minimum value of the coefficient of friction. (It can always be greater.)
Are you Alex, by any chance? Because my physics teacher's name is Alex...
