Frictional Torque for Static Equilibrium of a Pulley
10 replies · 7K views
BraedenP
A mass of 0.311kg is attached to one end of a string, and a mass of 0.625kg is handing off the other end. The string goes over a pulley which has friction in its axle.
What is the magnitude of frictional torque required to maintain static equilibrium?
[tex]\tau=rFsin\theta[/tex]
I figured that I'd just have to find the forces acted on the pulley by both masses, calculate the resulting torques created by both of them, and subtract them to find the torque required to "cancel" the net torque in the system.
Thus:
[tex]\tau_{net} \approx 0.52 - 0.26 \approx 0.26[/tex]
My answer wasn't right.. Am I getting the concept right and just making a calculation mistake? Or is my method completely wrong?
Thanks!
Doc Al said:
Your method sounds good to me. What's the radius of the pulley?
Oh, sorry. The radius is 9.5cm, so I just converted to m and solved.
OK.
Show how you made those calculations.
Doc Al said:
OK.
[tex]\tau=(0.095m)((0.311 \cdot 9.81)sin(90))\approx 0.26 N \cdot m[/tex]
[tex]\tau=(0.095m)((0.625 \cdot 9.81)sin(90))\approx 0.52 N \cdot m[/tex]
Hmm, I'm not getting it. I'm using the right formula, aren't I? And I'm pretty sure the angle is 90, since the force is directed straight down.
And I really hope I didn't make a mistake in the force/radius, because those are just simple!
Your formula is fine. But your arithmetic is a bit off. Plug those number into your calculator once more.
Oh.. Ugh! I had it in Radian mode the whole time from my Calculus homework..
So those should be 0.29 and 0.58 respectively, right?
D'oh! But you should know that sin90° = 1 without using a calculator!
Much better.
