Frictionless tension/pulley problem.
  • Thread starter Thread starter CandyApples
    Frictionless
The discussion revolves around a physics problem involving two climbers connected by a rope over a frictionless pulley on an incline. The climbers' weights are 110 kg and 125 kg, with the incline at 22.56 degrees. Participants explore applying Newton's second law to determine the tension in the rope and the acceleration of the climbers. Initial calculations lead to confusion regarding the forces acting on each climber, but through collaboration, they clarify that tension is constant throughout the rope. Ultimately, the correct acceleration is found to be approximately 2 m/s², with the tension calculated at 220 N after correcting an earlier arithmetic mistake.
CandyApples
Two people are trying to climb an iced-over mountain. They are connected by a rope which passes smoothly over a rock where the terrain bends (acting as a pulley). One climber (110kg) is on top on a horizontal surface while the other (125kg) is on a 22.56 degree incline. Assume the ice is frictionless and the climbers have no tools to aid their climb. What is the tension in the rope, and what would be their acceleration?
F = m*a and the variation T - mg = ma.
\SigmaFx = -T + mgsin(22.56)
\SigmaFy = N - mgcos(22.56)
Now I am unsure what to do next, as all previous problems assumed the object was at rest. Should I set both of these equal to ma then solve for the acceleration vector? The issue I run into with doing so is that there are two different masses to be concerned with in this problem.
-Thanks for any assistance in advance.
Those apply to the person on the slope. What about the person on the horizontal surface?
(Since the only motion is parallel to the surfaces, all you care about are forces parallel to the surfaces.)
You need to apply Newton's 2nd law to each mass, then combine the two equations.
the person on the slope would have the forces:
\SigmaFx = T
\SigmaFy = 0
Can I solve using T = 110(a) in my x force component for the other person, seeing as tension is constant throughout the entire rope?
Doing so gives:
T = 110a
F = -t + mgsin(22.56)
125a = -110a +125(9.8)(sin(22.56))
225a = 125*9.8*sin(22.56)
a = 2.09 m/s/s
then:
T = ma
T = 110*2.09
T = 229.9N
\SigmaFx = T
\SigmaFy = 0
That's for the person on the horizontal surface.
Sure.
Doing so gives:
T = 110a
a = 2.09 m/s/s
You made an error when adding 125 and 110. Redo the calculation.
oh my, it was 235. The new a is 2 and hence the tension is 220. Got too enthused that I solved the problem and made a silly mistake. Thank you very much for the assistance and thank you for saving me some embarrassment :).
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
