Fuel Consumption of a Ship Traveling at Near Light Speed
The discussion revolves around the fuel consumption of a ship traveling at near light speed, particularly focusing on the effects of time dilation and relativistic mass. Participants explore whether the ship would require more, less, or the same amount of fuel to maintain a constant velocity under these conditions, considering various scenarios including travel through a gas and in empty space.
  • Some participants propose that the ship would require more fuel due to increased mass at high speeds, referencing challenges faced in particle accelerators.
  • Others argue that if the ship is in empty space and traveling at constant speed, it would not need fuel to maintain that speed, but only to accelerate.
  • There is a suggestion that time dilation could potentially reduce the fuel required, although this is contested.
  • Some participants express confusion about the reference frames involved, questioning how time dilation affects fuel consumption from different perspectives.
  • One participant emphasizes that there is no change in fuel consumption for those on the ship, as they experience 'normal time', while outside observers perceive time differently.
  • Another participant highlights the misunderstanding of the concept of relativistic mass and its relevance to the discussion.
The discussion remains unresolved with multiple competing views on how time dilation and relativistic effects influence fuel consumption. Participants express differing opinions on whether fuel requirements change based on speed and reference frames.
There are limitations in clarity regarding the reference frames being used, and some participants note a lack of understanding of special relativity principles, particularly concerning time dilation and mass increase.
guss
Imagine this scenario: An "airplane" that runs on some type of fuel, let's say, liquid, reaches 90% of the speed of light. Once it achieves this speed, will the ship require less fuel due to time dilation, the same amount of fuel due to time dilation, or more fuel to maintain a constant velocity? The reason I use an airplane is obviously to just supply the problem with some kind of friction, in this case air resistance, so that fuel needs to be consumed to maintain that constant velocity.
The reason that less fuel could be consumed is because of time dilation. Time would move more slowly on the ship, thus (maybe) making less fuel contribute to more thrust.
Anyone have an answer?
Science news on Phys.org
it would need more fuel because the plane would be more massive at that speed.
And that is also why is is hard to accelerate particles near the speed of light in a particle accelerator.
Anything traveling that fast NOT in an entirely empty section of space would be destroyed due to friction.
Alright, I'll change the problem. We are in empty space, and the ship is accelerating contantly.
Note how I'm just asking about if more or less fuel would be required JUST due to time dilation. If less fuel were required, I would assume that the increased mass would increase the force required, thus making the same amount of fuel required.
Not to nit pick but if your out in empty space you would need to take your own oxygen,
Maybe you could have some nuclear powered rocket , i don't know if that would work tho
This is a poorly posed question. Less fuel than what? Than required to maintain zero velocity?
If it's going at constant speed, why would mass make a difference?
Anyway, I think OP understands that obviously the faster we go through air, the more fuel we need. But is this need for fuel related to speed by a simple function related to speed, or does, at some ridiculous speed, time dilation come into account, perhaps reducing the expected fuel required?
I think OP also clearly understands that conditions at sea level on Earth would not allow near-light speed travel. Let's Reduce the air density/ friction as necessary to make the problem work...
I thought he wanted to keep accelerating to c. But if he's out in free space it wouldn't require any fuel to keep at that speed.
He's not out in free space, he's traveling through a gas. I don't know how thick, but it's there and it's producing drag.
The ship continues to use fuel at the same rate according to the people on the ship. Due to time dilation, outside observers would say that the fuel is being at a lower and lower rate as the ship approaches light speed.
The question was changed to being in "empty space".
To maintain constant speed, you wouldn't need fuel.
You would only need fuel to continue acceleration.
There is a severe misunderstanding of basic SR here.
What time dilation are you talking about, first of all? There is a lack of clarity on the reference frame being used. In fact, I think there is a total confusion here as I suspect that the reference frame are being switched back and forth. There is no time dilation on the ship with respect to those traveling with the ship! Period! So how would there be any change in fuel consumption with respect to those on the ship? Do you notice any change in your fuel consumption? After all, according to some other galaxy, you are moving quite fast yourself!
There is also no "mass increase" here for the ship itself. In fact, the concept of "relativistic mass" is highly outdated. Even Einstein stopped using it later in life as it is a misleading concept.
Zz.
Zz.
I think that you are misunderstanding me. I'm bad at wording these things, sorry. Basically:
Would time dilation have any effect on the fuel consumption of a constantly accelerating ship traveling at near-light speed through empty space?
Reading my other reply above might make sense as well. And I see what you are saying, but wouldn't the same amount of fuel be able to make the ship accelerate for a longer period of time for inside observers, because the ship would go faster and faster even though it looked like the same amount of fuel was being used to them?
So, for example, let's say this ship was traveling at 90% of the speed of light. To outside observers, this ship would be about 32% as fast as the rest of the world, but wouldn't that mean the, let's say "jet" of fuel, would be burning for longer, thus contributing force for a longer period of time than it normally would (about 317%)?
guss said:
Would time dilation have any effect on the fuel consumption of an accelerating ship traveling at near-light speed through empty space?
No. The ships fuel consumption wouldn't change.
But it would appear lower to someone not on board the ship (someone stood on Earth).
For someone on the ship, though, wouldn't they experience a longer period of thrust per, say gallon of fuel?
No. The people on the ship (and the ship and the engines and the fuel) would experience 'normal time'. The time dilation is only apparent to outside observers within a different reference frame.
The only way they see the effects of time dilation is when they view the 'outside world'. People back on Earth would appear to be experiencing time extremely quickly.
I know that, but when a time-dilated force that is acting upon something moving significantly faster than normal, in this case the outside world, I would think something would change. But what you are saying makes sense, and that's what I was thinking. I'm just thinking too hard about it I suppose.
Time-dilated force? Does such a thing even exist?
I mean, there is some kind of jet, fueled by some liquid. For every gallon of liquid burned, it produces a force for a certain period of time. Travel at 90% of the speed of light, and that time the force is "there" increases by 317%. That's what I'm thinking anyway. Know what I'm saying?
The engine is under the same time frame as the rest of the ship.
The time on board the ship doesn't increase by any factor so far as the ship is concerned. Period.
The time the engine fires for does not change as far as the ship is concerned. The acceleration does not change as far as the ship is concerned. The force the engine produces does not change whether it is run at 1% light speed or 0.99% light speed.
An important point here, the force produced by the engine is constant unless you change how much fuel is provided. The force is independent of burn time.
If I fire the engine for 10 seconds I get 10kN of thrust for example. If I fire the engine for 100 seconds I still get 10kN of thrust. But, the amount of acceleration that will produce is different. I will accelerate more with the second burst than the first as it is acting on the ship for longer.
What you are confusing is two reference frames. You are mixing the engines thrust in the ships reference frame with the duration of burn of an outside observers reference frame.
If an outside observer (on Earth for example) was to look at the ship it would appear that the ship, it's crew, the engines etc are all in slow motion. But, the force produced, regardless of where it is observed is the same.
Actually, wouldn't people back on Earth appear to be experiencing time extremely slowly? As slow as the outside world is perceiving their time to be?
Because they can argue that their frame of reference is as valid as yours if you're on earth, and so from their perspective you are the one who's moving really quick. So to them you would appear to be experiencing time slowly, and to you you would also see them as experiencing time slowly?
units of force * time = units of momentum... interesting, so does momentum get increased by 317% than it would have otherwise?
Once again we are confusing reference frames here and you've got the quickly / slowly aspect completely backwards.
If the ship is your reference frame, time experienced by everything outside the ship (travelling less than your velocity) will appear to move very quickly. 1 year on the ship will be multiple years on Earth.
If the Earth is your reference frame, time on the ship will appear to move really slowly.
From Earths perspective, you (on the ship) will be experiencing time extremely slowly. Not quickly.
There are only three possible reference frames:
On the ship - everything moving faster than you is going to experience time slower, everything moving slower than you is going to experience time faster.
Off the ship, traveling faster than the ship - the ship appears to experience time faster than you.
Off the ship, traveling slower than the ship - the ship appears to experience time slower than you.
Again, confusing two reference frames. The engine force, multiplied by the time applied in the ships reference frame is what counts.
The momentum of the ship is the same regardless of reference frame.
Force itself has a time component. 1N = 1 (kg.m)/s^2. When you convert the engine burn time from ships reference (let's say 10 seconds) to Earth's reference (let's say 100 seconds), you also have to amend the force value to reflect the time dilation.
From the Earth's reference, the engine will provide less force per second than it will in the ships reference frame. Remember, 1 second on the ship could be 10 on the earth. So from the ships point of view, when it gives 10kN of thrust for one second, it has given 10kN of thrust over 10 seconds from the Earth's.
It's a bit simplistic, and it doesn't convert as easy as that. I've just given that as a very, very basic example based on my understanding.
Ahh, that makes perfect sense. I somehow forgot about that. Thanks for your replies.
No, sorry... this is a very bad misunderstanding of the twin paradox. Wrongusename is correct, BOTH observers see the other as having time passing very slowly. I suggest you read up on the paradox and its resolution before you mislead others.
To both observers (as I'm pretty sure I've mentioned in my previous posts) observe time passing normally.
But, the person on the ship will experience 'less' time passing than the person on the Earth.
The person on the ship may undergo 10 years of travel and return, to find the Earth has undergone 100 years.
Heck, I've just read the entire wiki article and don't see a problem. From the first line:
In physics, the twin paradox is a thought experiment in special relativity, in which a twin makes a journey into space in a high-speed rocket and returns home to find he has aged less than his identical twin who stayed on Earth.
The traveler remains in a projectile for one year of his time, and then reverses direction. Upon return, the traveler will find that he has aged two years, while 200 years have passed on Earth.
If a pair of twins are born on the day the ship leaves, and one goes on the journey while the other stays on Earth, they will meet again when the traveler is 5.14 years old and the stay-at-home twin is 10.28 years old.
This is why I kept mentioning reference frames. I'm not going through it all again, it's there numerous times for people to see and I don't see anything that says what I've previously posted regarding reference frames is wrong.
I really would like to see someone who truly understands this stepping in, my description is based on my understanding and it may / may not be completely wrong.
mack_10 said:
Travelling at near light speeds would require massive amounts of fuel, that why SF writers invented the ram scoop
http://en.wikipedia.org/wiki/Ram_scoop
Yes, but that doesn't have anything to do with fuel use / thrust due to time dilation as per the op.
Here is a very detailed page on the relativistic rocket problem, including fuel consumption assuming a 100% efficient conversion of mass to energy:
http://www.xs4all.nl/~johanw/PhysFAQ/Relativity/SR/rocket.html
You have mentioned twice in this thread that the people on board the ship will observe those back at home on Earth "speeded up". This is simply not the case. The observers on Earth will see time moving more slowly for those on the rocket. Those on the rocket will see time moving more slowly for those on the Earth.
The reason you get the difference in age is that at some point the rocket must ACCELERATE to get back to Earth so the two observers can compare their clocks and see how long they have been gone. But as we already pointed out, we are dealing with constant speeds at this point. Therefore, the situation is completely symmetric when the ship is moving with constant velocity.
  • · Replies 36 ·
9K
  • · Replies 55 ·
  • · Replies 39 ·
  • · Replies 101 ·
10K
  • · Replies 31 ·
  • · Replies 52 ·
  • · Replies 25 ·
