Functions in Mathematica - sort function
The discussion revolves around implementing a sorting function in Mathematica that sorts a list of numbers by comparing and potentially swapping adjacent elements. The focus is on using pattern matching and understanding control structures like loops and conditional statements in Mathematica.
  • One participant seeks to create a sorting function using pattern matching and asks how to iterate through a list and implement conditional swapping.
  • Another participant suggests using a For loop combined with an If statement to achieve the desired functionality.
  • A later reply presents a proposed implementation of the sorting function but raises questions about the syntax used in the If statement.
  • Subsequent responses identify and acknowledge a mistake in the syntax related to the use of semicolons and commas within the If statement.
Participants generally agree on the need for a loop and conditional statements, but there is disagreement regarding the correct syntax for the If statement, which remains unresolved.
There are limitations in the proposed implementation, particularly regarding the syntax and structure of the If statement, which may affect the function's execution.
Physics_rocks
Hi ,
I'm trying to write down the following function :
sort[list_]
it needs to sort a list of numbers by checking each two adjacent numbers and swap them
if it is needed , but it doesn't work . I need to implement it using Pattern Matching .
but I don't understand how can I interate in "list" , meaning how can I ask an "IF" question
such as If list < list[i+1] then swap(list,list[i+1]) .
10x
You are looking for a For loop + If statement?
Code:
For[i = 1; i <= Length[list]; i++;
  If[ test; whatToDoIfTestIsTrue; whatToDoIfTestIsFalse]
The last argument (whatToDoIfTestIsFalse) is optional, you can leave it (and the trailing semicolon) out
Code:
Thank you .
This would do ?
PHP:
sort[list_] :=
 For[i = 1 ; i < Length[list]; i++;
  If [ list[i] < list[i + 1] ; j = list[i + 1] ,
   list[i + 1] = list[i], list[i] = j; ]
I think you have the semicolons and commas reversed inside the If statement.
Whoops, you do.
My bad!
  • · Replies 0 ·
