Force & Volume Fundamental Units
  • Thread starter Thread starter Ki-nana18
    Fundamental Units
The fundamental base units for measurement include kilogram (kg), metre (m), candela (Cd), second (s), ampere (A), kelvin (K), and mole (mol). Volume is derived from the base unit for length, resulting in cubic meters (m³), not cm³. Force is also a derived unit, expressed as newtons (N), which equals m·kg·s⁻². Both force and volume do not have their own base units but are calculated from these fundamental units. Understanding these derivations is essential for accurate scientific measurement.
Ki-nana18
What are the fundamental base units for Force and Volume?
I think its cm3 for volume but not completely sure.
the fundamental units are
kilogram (kg)
metre (m)
candela (Ca)
second (s)
ampere (A)
kelvin (K)
mole (mol)
So for something like speed which has the formula speed=distance/time, the unit would be m/s
So for force, write down how you'd get force and then check the units for it.
There are no base units for force or volume. The units for those are said to be derived from the base units. So, volume would have the derived unit m3, derived from the base unit for length, m. Likewise the derived unit for force is N = m·kg·s-2, derived from the base units m, kg, and s.
Thank You!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
