Gas expansion at constant pressure
wavingerwin
2 moles of gas at 300 K at 0.02 m3 is expanded to twice the original volume at constant pressure, and then adiabatically until T = 300 K again.
assume monatomic gas. assume ideal.
determine the final volume
determine the heat supplied to the overall process
determine change in internal energy
[tex]PV = nRT[/tex]
[tex]TV^{\gamma-1} = TV^{\gamma-1}[/tex]
State 1
n = 2
V = 0.02
R = 8.31
T = 300
P = 249.3 kPa
State 2
P = 249.3
V = 0.04
T = 600 K
State 3
T = 300
monatomic therefore [tex]\gamma=5/3[/tex]
V = 0.061
so final volume is 0.061 m3
I am struggling to find the "heat supplied" to the system. Since from state 2 to 3 the process is adiabatic, Q = 0.
So the only heat transfer occur from state 1 to 2.
Would it just be equal to the work?
so Q = W = P(V2-V1) = 249300 x 0.02 = 5 kJ?
and so the change in internal energy must also be be 5 kJ?
thank you in advance.
How can you make the gas expand at constant pressure?
ehild
Hi ehild
by applying heat and raising its temperature.
However, I don't have/know an equation that equates total heating applied (Q) to the raise in temperature..
What about specific heat capacity at constant pressure?
ehild
specific heat, c would equal du/dT
so I guess the heat supplied, q, would equal change in u = c dT
but c is not given in the question.
It is 2 moles of mono-atomic ideal gas. Look after cp.
ehild
  • · Replies 67 ·
