Does pressure decrease when the real volume is reduced
In summary, according to Boyle's Law, pressure and volume are inversely proportional, meaning that when the real volume is reduced, the pressure will increase. This is due to the fact that the molecules of gas become more crowded and collide with the walls of the container more frequently. When the temperature remains constant, reducing the volume will result in a decrease in pressure. While reducing the volume can also affect the temperature and number of gas molecules, pressure is the only variable affected if these factors are constant. The decrease in pressure when the real volume is reduced can also cause gas molecules to move more rapidly and spread out, resulting in an increase in volume. This behavior of gases is described by the ideal gas law, which states that pressure, volume,
What is the relationship between attractive forces and real volume of a real compared to a ideal gas?
Does pressure decrease when the real volume is reduced and the attractive force is increase?
Chemistry news on Phys.org
Real volume?
real volume as in a gas particle as volume. Ideal gases are assumed to have negligible volume
This should help you.
I can provide a response to this question based on the principles of gas laws and molecular behavior. According to Boyle's Law, pressure and volume are inversely proportional, meaning that as the volume of a gas decreases, the pressure will increase and vice versa. This is assuming that the temperature and amount of gas remain constant.
In terms of the relationship between attractive forces and real volume, it is important to understand the concept of an ideal gas. An ideal gas is a theoretical gas that follows the gas laws perfectly, with no intermolecular forces between its particles. In contrast, a real gas has intermolecular forces between its particles that affect its behavior.
When the real volume of a gas is reduced, the particles are forced closer together, increasing the frequency of collisions and therefore increasing the pressure. Attractive forces between particles can also contribute to this effect by bringing the particles closer together. This is why, in general, a real gas will have a slightly higher pressure compared to an ideal gas at the same temperature and volume.
However, the exact relationship between attractive forces and real volume can vary depending on the type of gas and its properties. In some cases, increasing attractive forces may actually decrease the pressure, as the particles may become more tightly bound and less likely to collide with each other. Therefore, it is not always accurate to say that pressure will decrease when the real volume is reduced and attractive forces are increased.
In conclusion, pressure and volume have an inverse relationship according to Boyle's Law, and attractive forces can play a role in this relationship in a real gas. However, the exact impact of attractive forces on pressure and volume can vary and cannot be generalized without considering the specific properties of the gas in question.
1. How does pressure change when the real volume is reduced?
According to Boyle's Law, pressure and volume are inversely proportional. This means that as the volume decreases, the pressure increases. Therefore, when the real volume is reduced, the pressure will also decrease.
2. Why does pressure decrease when the real volume is reduced?
This is due to the fact that when the volume decreases, the molecules of gas become more crowded and collide with the walls of the container more frequently, resulting in a higher pressure.
3. Will the pressure decrease if the real volume is reduced at a constant temperature?
Yes, according to Boyle's Law, as long as the temperature remains constant, pressure and volume are inversely proportional. So, if the volume decreases, the pressure will also decrease.
4. Is pressure the only factor affected when the real volume is reduced?
No, reducing the volume can also affect the temperature and the number of gas molecules present. However, if these factors remain constant, then pressure will be the only variable affected by a decrease in real volume.
5. How does the decrease in pressure when the real volume is reduced affect the behavior of gases?
The decrease in pressure can cause the gas molecules to move more rapidly and spread out to occupy a larger space, resulting in an increase in volume. This phenomenon is known as the ideal gas law, which states that pressure, volume, and temperature are all interrelated in the behavior of gases.
  • Chemistry
