How can an equation produce the iconic Gateway Arch using a catenary curve?
  • Thread starter Thread starter turnip
    Formula
A catenary curve can represent the Gateway Arch using the equation y = a/2 (e^(x/a) + e^(-x/a)), where 'a' is a constant. To derive the specific equation for the arch, one must consider the dimensions: the arch is 630 feet high and 630 feet long. The challenge lies in determining the value of 'a' by substituting the known coordinates into the equation. A suggested approach involves solving the equation a + 630 = a/2 (e^(-315/a) + e^(315/a)) numerically for 'a'. This allows for adjustments to fit the arch's shape and orientation.
turnip
A catenary curve can be described by the following function:
y= a/2 (ex/a + e -x/a)
where a is a non-zero constant
By selecting sutable axes, devise an equation that will produce the gateway arch.
Right next to the question is a graph of an arch that is 630 feet high (on the y axis) and 630 feet long (on the x axis).
I have no idea where to start. I was thinking that I could substitute the x and y values in of 630 to find the a value and thus the normal function (since its constant). But then why not just ask for that? Why go and say devise an equation, i don't follow.
Please, I would really appreciate someone getting me started on this!
Mathematics news on Phys.org
here's what i could get:
y = a(e^x/a + e^-x/a)/2
630 x2 = a(e^630/a + e^-630/a)
1260/a = e^630/a + e^-630/a
ln 1260/a = 630/a -630/a = 630 - 630/a
then that would mean 0/a which is infinity (iam getting the idea that isn't the answer)
where am i going wrong?
You aren't describing the graph sufficiently. What is the value of y when x= 0? You say it is "630 feet long (on the x axis)". Is the y value when x= 630 the same as when x= 0? And you say that it is "630 feet high (on the y axis). For what x is that? 630/2= 315?
I have just been given this exact question to complete as part of an assignment.
Any hints or ideas how to devise a formula for the Gateway Arch.
Im a bit stuck.
Thanks.
You said there was a picture- we do not have the picture.
Not unless you can answer my questions.
Im a bit stuck.
Thanks.
Without the diagram we have to make a few assumptions but I'll bite.
Assume that the equation is valid over the full arch and that you can shift it up or down by an arbitrary amount. Initially I'll take "a" positive and make an upside-down arch, but you can flip it later by negating "a".
Clearly y() has even symmetry and it's min is at x=0.
The min is y(0) = a so to fit the requirements we want y(+/- 315) = a + 630.
So all you need to do is solve the following transcendental equation numerically for "a",
a + 630 = a/2 ( exp(-315/a) + exp(+315/a) )
Flip it upside-down and shift it up or down as required.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
