Why Does Diatomic Hydrogen Form Despite Zero Net Electric Field?
Diatomic hydrogen readily forms due to van der Waals interactions between hydrogen atoms, despite the zero net electric field dictated by Gauss's law. In isolated conditions, hydrogen atoms induce dipoles in each other, facilitating molecular formation. However, stable diatomic hydrogen requires three-body collisions or interactions with surfaces to dissipate bonding energy, as two colliding hydrogen atoms alone do not suffice for molecular formation. This phenomenon is particularly observable in low pressure and low temperature environments in space.
  • Understanding of Gauss's law and electric fields
  • Familiarity with van der Waals interactions
  • Knowledge of atomic hydrogen behavior in low pressure environments
  • Concept of three-body collisions in molecular formation
  • Research the principles of van der Waals forces in molecular chemistry
  • Study the effects of temperature and pressure on atomic hydrogen states
  • Explore the mechanisms of three-body collisions in gas-phase reactions
  • Investigate the role of surface interactions in molecular formation
Students and researchers in physical chemistry, astrophysics, and molecular physics, particularly those interested in the formation of diatomic molecules in low-pressure environments.
Tom MS
Say you had two isolated hydrogen atoms. Because of the spherical distribution of electronic charge on each hydrogen and the net charge of 0 outside each atom, wouldn't Gauss's law dictate a 0 net electric field outside each atom? If this is the case, why does diatomic hydrogen so readily form?
I know that in extremely low pressure, low temperature situations in space, there are large clouds of atomic hydrogen, so do random thermal collisions bring hydrogen into its diatomic state?
While an isolated atom in its ground state has no dipole moment, two atoms will induce dipoles in each other. This is known as the van der Waals interaction. (Classically, you can see it as the charge distribution of the electron as being isotropic on average, but not at any given instant.)
Two colliding hydrogen atoms will not form a molecule, as there is no fast decay channel through emission of a photon. You need three-body collisions, or interaction via a surface, to be able to take the bonding energy away and be left with a stable molecule.
  • · Replies 83 ·
  • · Replies 29 ·
  • · Replies 26 ·
  • · Replies 30 ·
