Gauss' Law - Planar Symmetry HELP
The discussion focuses on applying Gauss' Law to calculate the electric field from a charged square plate. For part (a), the electric field near the center of the plate should be calculated using the equation E = (Omega)/(2e), where Omega is the surface charge density, as the distance is small compared to the plate size. In part (b), the plate can be treated as a point charge at a distance of 62 m, using the equation E = [1/(4πe)] [q/r^2]. The confusion arises from incorrectly incorporating distance into the infinite plate scenario, where it is not needed. Understanding the distinction between the two scenarios is crucial for accurate calculations.
yanimated
A square plate of edge length 9.0 cm and negligible thickness has a total charge of 6.3 x 10-6 C.
(a) Estimate the magnitude E of the electric field just off the center of the plate (at, say, a distance of 0.50 mm) by assuming that the charge is spread uniformly over the two faces of the plate.
(b) Estimate E at a distance of 62 m (large relative to the plate size) by assuming that the plate is a point charge.
E = magnitude of electric field
Omega = Surface Charge Density
e = 8.85 x 10^-12 C^2/Nm^2
pi = pi (ie 3.14...)
r = radius
q = Charge
E = (Omega)/(2e)
and then I used E = [ 1/(4pie) ] [ q/r^2 ]
Well, I first used the second equation there with q = 6.3 x 10^-6 C
and r = .5 mm = .0005 m to find the magnitude of the electric field.
And then I plugged what I got there into E = (Omega)/(2e) to find Omega.
That was wrong :(. What am I doing wrong? Is there another equation?
mmm... (a) is just the case of finding E field for an infiinitely large plate for the distance to plate is small compare to plate size... so r does not comes in at all...besides you had E = (Omega)/(2e), nowhere is there a "r" in here!
(b) as suggested by the hint, treat it as a point charge
"just off the center of the plate (at, say, a distance of 0.50 mm)"
So wouldn't the .50mm be the radius? Or am I just still not getting it?
IF you consider that the plate is effectively an infinite plate, THEN you use E=(Omega)/2e as suggested by you... and there is no "r" in this equation!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
