Gauss Law Problem to determine F/A
The discussion revolves around calculating the force per unit area (F/A) on three parallel charged sheets using Gauss's Law. The sheets have surface charge densities of 7.9 nC/m², -3.3 nC/m², and 5.4 nC/m², respectively. Initial attempts to derive the electric field and force per unit area included equations like E = σ/2ε₀ and F = q'E, but the results were deemed incorrect. Participants are seeking clarification on the correct application of these principles to find the forces acting on each sheet. The conversation emphasizes the need for accurate calculations and understanding of the relationships between charge density and electric fields.
max190us
Three large but thin charged sheets are parallel to each other as shown in the figure . Sheet I has a total surface charge density of 7.9 nC/m^2, sheet II a charge of -3.3 nC/m^2, and sheet III a charge of 5.4 nC/m^2.
Figure:
----------------(I)
----------------(II)----------------(III)
Estimate the magnitude of the force per unit area on sheet I, II, and III, N/m^2.
**I do not know how to start**
Attempt: E=F/Q; Int(E) dA=Q/epsilon
2. E=F/Q; Int(E) dA=Q/epsilon; \sigma=Q/A
3. I combined the above eq and got this:
\sigma*(\sigma)/(2epsilon)
The attempt I have done:
E = σ/2εo
The force per unit area on sheet I due to sheet II is:
F = q’E = σ’AE => F/A = σ’E = σ’(σ/2εo) = 3.3x10^-9(7.9x10^-9)/2*8.85x10^-12
F/A = 1.47x10^-6 N/m²
or
FI/A = -σσ’/εo= (3.26x10^-6),
FII/A = -σσ’/εo + σσ”/εo
FIII/A = σ’σ”/εo
---IT IS NOT RIGHT! HELP ME!
