Gauss's Law and Coaxial Cables
In the discussion on Gauss's Law and coaxial cables, a cross-section of a charged coaxial cylinder system is analyzed. The inner cylinder has a positive linear charge density λ, while the outer cylinder has a negative density of -2λ. The electric field inside each metal cylinder is zero due to electrostatic equilibrium, as charges redistribute to cancel internal fields. Outside the outer conductor, the electric field is radially symmetrical and can be derived using Gauss's Law, which relates the electric field to the enclosed charge. To find the charge in terms of λ, one must consider the linear charge density and the length of the cylinder when calculating the enclosed charge and surface area for the Gaussian surface.
tZimm
The diagram I've attached shows a cross-section view of a very long straight metal cylinder of radius r1 within a coaxial hollow metal cylinder of inner radius r2 and outer radius r3. The inner cylinder has
a positive charge per unit length λ, whereas the outer cylinder has negative charge per unit length
-2λ. There are no other objects nearby.
So I know the field lines point radially outwards from the inner conductor to the outer conductor. But the following is what I am not sure with:
1. Why the field within each metal cylinder is zero during electrostatic equilibrium?
2. Why the electric field in the region outside of the outer conductor (region D) must be radially symmetrical and is this field equal in strength as the field in region B?
3. Using Gauss’s law to derive an expression for the electric field magnitude in regions B and D as a
function of the distance r from the center. The answer should be in terms of the linear charge
density, the relevant radii and the electrostatic constant. I have no no idea how to include linear charge density in this derivation.
Thanks in advance to whoever answers!
Is this a homework question?
on 3. How would I find charge in terms \lambda and an arbitrary length of the cylinder.
We need to draw a cylinder in region B, how much charge is enclosed in my surface. What is the surface area in terms of the radius from the center and an arbitrary length of the cylinder.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
