Gearbox Design: Increasing Torque and Speed?
Increasing both torque and speed simultaneously in a gearbox design is fundamentally impossible due to the power equation, which illustrates the tradeoff between these two variables. While a continuously variable transmission (CVT) can optimize performance by allowing for variable gear ratios, it does not truly achieve both increased torque and speed at the same time. The discussion confirms that one must choose between higher RPM or greater output speed, as there is no workaround without violating physical principles. The consensus emphasizes that understanding these limitations is crucial for effective gearbox design. Exploring CVTs may provide some flexibility, but they won't solve the inherent tradeoff.
cosmarchy
I suspect I already know the answer to this question but I want to ask in case anyone has any ideas on how to improve things.
What I am looking for is a gearbox design that will increase both torque and speed at its output. I don't think this is possible as I believe one is traded off against the other but as I said I could be wrong.
Is this possible? Are there any ways around this?
Thanks
You're correct, it can't be done because of this formula (well not because of the formula, but the formula results from the physical reality that prevents it):
Power = ( rpm x torque ) / constant
The constant will change depending on what units you select for power and torque.
So yes, that's the tradeoff you mentioned... The only thing that might come close depending on your application is possibly a continually variable transmission (CVT)? That would allow you to run your motor at a fixed RPM while changing the output speed. As it has an effectively infinite number of gear ratios you can tune your setup for either, say, peak efficiency for peak power output, etc.
Absolutely not going to fit all applications, however.
Ok thanks for confirming this :) that's what I thought.
I'll have a look at the CVT and see how this works and whether it'll fit in some where.
Thanks
Right...you trade off rpm for speed. One or the other, but not both.
No way around it without violating a very fundamental property of our universe.
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
