General equations for powering a model aircraft
For building a FPV model aircraft weighing around 5kg with a wingspan of 2.5-3m, determining the required power involves scaling from larger aircraft. It is suggested to research "watts per pound" for similar models to estimate power needs, using the formula that divides watts by 745.7 to convert to horsepower. The power requirement scales with the fourth power of the length ratio, meaning a model at 1/6 scale of a 1000 hp aircraft would need approximately 0.77 hp. Most model aircraft typically operate at higher power-to-weight ratios than full-scale planes, allowing for better performance. Understanding these principles is crucial for effective motor sizing and achieving desired flight speeds.
ammtst
I was looking at building a fpv plane. I was wondering if anyone could help me with the basic equations i would need for motor sizing etc. Just how I would go about finding power required. Looking at about a loaded weight of about 5kg wingspan 2.5-3m. Not sure of speed maybe around 40-70kph.
Welcome to the PF.
fpv = "First Person View"?
When you look at model airplanes that are around the size you want to build, what size engines do they typically use?
Welcome to the PF.
yeah first person view. Nothing really around that size and that weight range that's all. And most are using an electric was thinking of using a petrol. Like could i use a direct ratio in terms of weight to power and just scale up or down as required. Or do I need to go through dimensional analysis and all that stuff
As a first approximation, you can scale down the power required for a 'big' airplane. We may assume that the weight scales as L3 and that the airspeed scales as L1, so the power required would scale as L4. The glide ratio L/D is assumed to be equal, which may not be correct, due to the Reynolds number being different.
If your model is built -for example- at 1/6 scale, and the 'big' airplane needs 1000 hp, the power required for your model would be 1000 x (1/6)4 = 0,77 hp
A lot of model aircraft fly faster than scale speed, and typically, they have a higher power to weight or drag ratio than a full scale aircraft. At the upper end of the watts per pound range, you have models than can hover and climb while vertically oriented.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
