Solve for Force Exerted by Spring on Ball | General Physics Problem Help
The discussion centers on solving a physics problem involving a spring and a ball in circular motion. The spring has a relaxed length of 1.0m and a spring constant of 200N/m, with a ball of mass 0.05kg attached, creating a new spring length of 1.4m. The initial calculation for the force exerted by the spring on the ball is determined to be 80N. The follow-up question involves finding the ball's speed, with a focus on using centripetal force equations. Participants clarify that the centripetal force formula, F = mv²/r, is essential for determining the velocity without needing the period.
sixstringartist
Im having difficulty with a physics problem and was looking for help.
The problem states: A spring has a relaxed length of 1.0m, when no force is acting to stretch or compress it. It has a spring constant k = 200N/m. A ball of mass .05kg is attached to one end and it is made to go in circle with radius 1.4m, the new length of the spring. Assume that gravity and air resistance can be igmored. What is the magnitude of the force exerted by the spring on the ball?
This I got: F_mag = k_s * delta s = 80N
The follow up problem is: For the ball in circular motion in the problem above, what is its speed.
This is what gets me. I don't know how to find velocity without knowing the period.
Any help is greatly appreciated.
Hint: The motion is circular. What's the acceleration of the mass?
The centripetal force is equal to \frac{mv^2}{r}.
v:velcity
r:radius
Can you take it from there ?
marlon
v:velcity
r:radius
marlon
yes that's it! thank you! It all makes sense, b/c all I could find is v^2 = G *(M/R) for orbiting bodies which is basically the same formula. Thanks again.
