Generating functions, binomial coefficients
13 replies · 3K views
Sarina3003
a) I have to find and expression for sequence of $b_n$ in terms of generating functions of the sequence of $a_n$
$$b_n = (-1)^{n}(n+1)a_0 +(-1)^{n-1}n a_1+...+(-1)2a_{n-1}+a_n$$ with $$a_n = a_{n-1} +8a_{n-2} -12a_{n-3} +25(-3)^{n-2} + 32n^2 -64$$
b) I have to use the result of a) to prove this identity
$${\beta \choose n} = \sum_{x = 0}^{n}(-1)^{x}(x+1) {\beta+2 \choose {n-x}}$$ with $\beta$ is a complex number
[/B]
All necessary information are given above
3. The Attempt at a Solution
What I've already had is the GF of $a_n$ which is
$$\frac{120}{1-2z} + \frac{150}{(1-2z)^{2}} -\frac{125}{1+3z} + \frac{-3}{(1+3z)^{2}} + \frac{-83z^{2} + 202z -135}{(z-1)^{3}}$$
Please shed some lights. Any hints would be greatly appreciated
[/B]
Please refrain from typing your material in a bold font.
Anyway, you need to specify some boundary conditions on the ##a_n##, such as values of ##a_0, a_1## and ##a_2##. If you give different boundary conditions you will get different sequences ##\{ a_n \}## and so different generating functions.
You need to figure out how to express the generating function ##B(z) = \sum_{n=0}^{\infty} b_ n z^n## of ##\{b_n \}## in terms of the generating function ##A(z) = \sum_{n=0}^{\infty} a_n z^n## of ##\{ a_n \}##.
Thanks for that. Should i take the sums of both sides and see what happens? I’m not sure if it is ok since this is a sequence
Sarina3003 said:
Thanks for that. Yeah i know that, it is the question . But i don’t know how to start off since the recurrence relation they have for $b_n$ includes both terms $a_n$ and $b_n$
Were you given the generating function ##A(z)## as part of the problem statement? If so, you can expand it in powers of ##z## (or, at least find the first few terms) to actually obtain explicitly the values of ##a_0, a_1, a_2##. If you were not given the generating function ##A(a)## you must have known the values of ##a_0, a_1, a_2## when you computed it.
Anyway, the first few terms of your ##b_n##-recurrence read as
$$\begin{array}{rcl}
b_0 &=& a_0 \\
b_1&=& -2 a_0 + a_1 \\
b_2 &=& 3 a_0 - 2 a_1 + a_2 \\
b_3 &=& -4 a_0 + 3 a_1 - 2 a_2 + a_3 \\
\vdots & \vdots & \hspace{2ex}\vdots
\end{array}
Thus, we have
$$B(z) = a_0 - 2 a_0 z + 3 a_0 z^2 + \cdots -2 a_1 z^2 + 3 a_1 z^3 + \cdots \\
+ a_2 z^2 - 2 a_2 z^3 + \cdots + a_3 z^3 - \cdots $$
Isolate the total coefficients of each ##a_i##, then sum up the results.
b_0 &=& a_0 \\
\end{array}
Thus, we have
Thanks so much. Yes i know a1, a2 and a0 but i used it to get GF of an. But how is it helpful in this question?
It might not be; it is just that your presentation of the question was incomplete, and I wanted to know if you realized that. If I want to check your GF myself, I would need that information.
a0 =130, a1=215, a2=260, here they are. If you have some time, please also help me to check it whether i got it right or wrong, just by the way. Thank you :D
Also, do you have any idea for b). I got the answer for a) now, thanks to you, it looks little bit different from the identity in b) and so i guess i have to do a little bit of work to somehow use the answer from a) and arrive to the identity but since this is power series it is more little complicated to handle so i am still stuck at it :( Particularly, dealing with this bit $${\beta+2 \choose {n-x}}$$
You made an error somewhere. If we expand your given GF in powers of ##z## and look at the coefficients of ##z^0, z^1, z^2## we get ##a_0 = 277, a_1 = 1436## and ##a_2 = 1361.##
If I take your ##a_0 = 130, a_1 = 215, a_2 = 260## and substitute those into the recursion, then solve it-- or, rather, let the computer algebra system Maple solve it by finding the generating function-- I get a completely different GF from yours.
I don't think the PF rules will let me present the exact form of the GF.
However, even using the (incorrect) initial conditions ##a_0 = 277, a_1 = 1436## and ##a_2 = 1361## in your recursion, Maple still gets a completely different GF from yours, so that means that your GF would not lead to a correct solution of the recursion. Somewhere, the values of ##a_3, a_4, \ldots## obtained using the (incorrect) initial conditions in the recursion would be different from the values obtained by expanding out your GF in powers of ##z##.
Thanks for pointing out. I have used Mathematica and typed straight in a[n] and solve it with boundary conditions and it gave me the answer include exponential which i have not seen along the way finding its solution including particular solutions . Have you seen something like that in Maple?
And yeah i did have mistakes, i have checked it, and even when i corrected it it also does not give me any exponential term :(
I am attempting to attach a pdf image of my Maple worksheet; I don't know if it will work as intended.
Oops: I see I had a wrong recursion; I wrote -64 instead of -64n on the right. I will do it again.
Attached is the new worksheet.
I forgot to simplify the result, but when I ask Maple to do that it gives
$$a_k =(-1)^k 3^k k+5(-1)^{k+1} 3^k+8k^2+60k+135.$$
This looks different from the Mathematica result, but I have checked it out in detail: it really does solve the recursion. (I got Maple to check this after making the pdf file, so that check is not included in the attachment.)
Thank you. I have checked my calculation by hand and plug in a0,a1 and a2 and verify that it works now! Thanks for your sheets I have learned some codes in Maple as well and it would be useful when I encounter it in the near future. Thanks again :):)
Presumably, you need to figure out how to get ##B(z) = \sum_{n=0}^{\infty} b_n z^n## before you can proceed further. I hinted at one way to do it in post #4, but another way is to note that the ##b_n## sequence is the convolution of the ##a_n## sequence and the sequence ##\{ c_n , n = 0,1,2, \ldots \} = \{ 1, -2, 3, -4, \ldots \}##. It is quite easy to get the GF ##C(z) = \sum c_n z^n## and you can then apply some standard properties of GF to get the answer.
