Geometry of circles and polygons.
An equation has been proposed for calculating the perimeter of regular polygons that are tangentially touching circles, expressed as P=Dn*tan(180/n), where P is the perimeter, D is the circle's diameter, and n is the number of polygon sides. The original intent was to approximate pi, but doubts arose regarding its utility for that purpose. The discussion highlights the challenge of computing the tangent function accurately, especially in the context of using calculators. While the equation may not serve to approximate pi, it sparked mathematical curiosity among participants. The potential for alternative applications of the equation remains uncertain.
JDude13
I have found an equation which deals with regular polygons touching circles tangentially with each of their sides.
P=Dn\tan(\frac{180}{n})
where
P is the perimeter of the polygon.
D is the diameter of the circle.
n is the number of sides on the polygon.
i originaly thought it would be useful for approximating pi but now I am not sure it has a use.
Tell me what you think.
Mathematics news on Phys.org
Depends partly on how you planned to compute the tangent function.
Umm... I am in yr 11
degrees, i guess. Should i have specified that? I couldn't figure out how to put the degrees sign in LaTeX.
I guess what was trying to say is that actually computing tan x is the trick. If you can already do it with, say, a calculator, then you don't really need to "approximate" pi! :)
do you mean that because I am using a calculator that i may as well just go
\pi=
I guess youre right.
But since its not used for approximating pi, at least it fueled my mathematic curiosity for 15 mins :P
Maybe it has a use somewhere else... :/
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
