Given a Matrix A, find a Product of Elementary Matrices that equals A
WTFsandwich
Given
A = \left( \begin{array}{cc}<br /> 2 &amp; 1 \\<br /> 6 &amp; 4 \end{array} \right)
a) Express A as a product of elementary matrices.
b) Express the inverse of A as a product of elementary matrices.
Using the following EROs
Row2 --> Row2 - 3 * Row1
E_{1} = \left( \begin{array}{cc}<br /> 1 &amp; 0 \\<br /> -3 &amp; 1 \end{array} \right)
Row1 --> 1/2 * Row1
E_{2} = \left( \begin{array}{cc}<br /> 1/2 &amp; 0 \\<br /> 0 &amp; 1 \end{array} \right)
Row1 --> Row1 - 1/2 * Row2
E_{3} = \left( \begin{array}{cc}<br /> 1 &amp; 0 \\<br /> -2 &amp; 1 \end{array} \right)
Multiplying all the Elementary matrices together, I got the Product
P = \left( \begin{array}{cc}<br /> 2 &amp; -1/2 \\<br /> -3 &amp; 1 \end{array} \right)
Which is A-1.
Note that the inverse of A-1 is A and also that given invertible A and B, (AB)-1=B-1A-1
You have E1E2...En=A-1 where Ei is an elementary matrix. So take the inverse of the whole thing
If I'm understanding you correctly, I should take the inverses of all the elementary matrices and multiply those, and it should give me A?
Essentially, (E1E2...En)-1 = A
Hey Sandwich,
Think of the matrix A as being equivalent to an identity matrix of the same size, but just manipulated by elementary row operations.
Vee is right, because if you multiply the inverse of A by A's corresponding elementary matrices, the product is the identity matrix. Try it out.
A=I(E1E2...En)^(-1)
Hope that helps!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
