What is the period of the ISS orbit?
  • Thread starter Thread starter KCEWMG
    Orbit Radius
The International Space Station (ISS) orbits Earth at an altitude of 347 km, requiring calculations to determine its orbital period. The correct formula to use is T^2/R^3 = (4Pi^2)/(GM), where 'R' must include the Earth's radius plus the altitude of the ISS. A common mistake is using only the altitude, which leads to incorrect results, such as 1.1 seconds instead of the correct period of 91.3 minutes. The proper distance 'R' is the sum of the Earth's radius (approximately 6,371 km) and the ISS's altitude, totaling about 6,718 km. Accurate calculations are essential for determining the orbital period of the ISS.
KCEWMG
The International Space Station (ISS) circles the Earth at an altitude of 347 km.
What is the period of the orbit of the ISS expressed in minutes?
G=6.67x10^-11 N * m^2 /kg^2
M(Earth)=5.98*10^24 kg
So: T^2= Sqrt(((4Pi^2)/(GM))*(r^3))
Alright, so I've been plugging in these numbers for awhile, and I keep getting the wrong answer: 1.1 seconds. The right answer is 91.3 min.
T is in seconds when initially calculated, right? I'm still doing something wrong, but I'm hoping to just double check on that.
Welcome to PF, :smile:
I'm not sure what numbers you're plugging in, but keep in mind that the 'R' in Newton's law of gravitation is the distance between the centres of mass of the two bodies. What is the distance between the ISS and the centre of mass of the Earth? Hint: it is not 347 km.
Ahh, 347000 m + 6.37x10^6 m! Perfect, thanks!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
