Finding Global Extrema on Disc x^2 + y^2 ≤ 1 for f(x,y) = xy + 5y
  • Thread starter Thread starter jonroberts74
    Disc Global
jonroberts74
find the global extrema on the disc x^2 + y^2 \le 1
given the function f(x,y)=xy+5y
For the interior of the disc
\nabla f = <y,x+5>
the critical point is (0,-5)
for the boundary of the disc
using lagrange multipliers
\left\{\begin{array}{cc}y=\lambda 2x \\ x+5 = \lambda 2y \\ x^2+y^2 =1 \end{array}\right.
solving for lambda
\lambda = \frac{y}{2x}; \lambda = \frac{x+5}{2y}
\frac{y}{2x}=\frac{x+5}{2y} \Rightarrow y = \pm \sqrt{x(x+5)}
now,
x^2 + (\pm \sqrt{x(x+5)})^2 = 1 \Rightarrow x = \frac{1}{4}(\pm\sqrt{33}-5)
subbing the x value into
y = \pm \sqrt{x(x+5)} \Rightarrow \pm \sqrt{\frac{1}{8}(5 \sqrt{33} - 21)}
I know to test those critical points in the original function but before I go further I want to make sure I have done everything up to it correctly
\nabla f = <y,x+5>
solving for lambda
now,
I got the same numbers using a different method.
Likes 1 person
\nabla f = <y,x+5>
solving for lambda
now,
Be careful: one of your ##x =\frac{1}{4}(\sqrt{33}-5)## and ## x =\frac{1}{4}(-\sqrt{33}-5)## is incorrect; do you see why?
It would have been less troublesome to use the Lagrangian stationary conditions to solve for ##x,y## as functions of ##\lambda##, then use these expressions in the constraint to get a single equation for ##\lambda##. The two roots for ##\lambda## correspond to the min and the max, and when you then use those values in the ##x,y## expressions you are done: no ##\pm## problems to worry about.
I am not currently aware of Lagrangian stationary conditions. I will use my googles but I always welcome better ways to do a problems. especially ones with less than optimal results.
I'll check those x values in the morning.
EDIT:
I found something about creating a new function and taking partials
F(x,y,z,\lambda)=f(x,y,z) - \lambda(g(x,y,z)-k)
and take the partials for x,y,z,lambda
You are aware of the conditions: you used them! They are just the two equations ##x+5 = 2 \lambda y## and ##y = 2 \lambda x##. These are the "stationarity" conditions for the Lagrangian function ##L = f(x,y) - \lambda g(x,y)## in the problem
\min f(x,y)\\<br /> \text{subject to } g(x,y) = 0
BTW: the Lagrangian ##L## plays an important role in second-order tests for maxima and minima, but more on that later.
Likes 1 person
ah, okay thank you. I just hadn't heard that terminology used yet.
I went through it again, got the same number. I am not seeing why one of the x values is incorrect
Whenever you use nonlinear manipulations (squaring equations, and the like) you can introduce false solutions, that is, so-called solutions that do not satisfy the original equations you started with. Check both ##x = (1/4)(\sqrt{33}-5)## and ##x = (1/4)(-\sqrt{33}-5)##. There is no way that one of them can possibly satisfy ##x^2 + y^2 \leq 1## for any real value of ##y##. If you don't believe it, try evaluating them numerically.
