Auto/Motor How can I calculate the resistance force for an electric Go Kart?
  • Thread starter Thread starter Pablo87
    Force Resistance
The discussion centers on designing an electric go-kart and calculating the resistance forces affecting its deceleration, specifically rolling resistance and aerodynamic drag. The original poster, Pablo, is analyzing a speed/time graph from a test where the motor was disengaged, allowing the kart to decelerate due to resistive forces. He outlines his approach to derive a polynomial equation for resistance force, aiming to find constants through integration of the deceleration equation. However, he encounters difficulties using Excel Solver to find a solution.Contributors provide insights on measuring drag and rolling resistance, suggesting that having enough data points and covering a wide speed range are crucial for accurate modeling. They recommend an empirical method for determining coefficients, which involves coasting the vehicle under controlled conditions and measuring deceleration. This method simplifies the process compared to Pablo's approach and may yield better results. The discussion highlights the importance of polynomial regression and empirical data in accurately modeling vehicle resistance forces.
Pablo87
Hello to all,
I am trying to design an electric Go kart as part of a personal project. I am now in the preliminary design phase, trying to find some literature regarding to the resistance force (Rolling resistance + aerodynamic drag).
I was able to find a document in which some guys did some testing, obtaining a graph speed/time (I understand that the controller was plotting a graph of values of speed and time). The graph shows how they disengaged the motor with a clutch and left the kart to decelerate by its "own" (in reality due to all the resistances = Rolling + aerodynamic...considering the bearing friction and rolling resistance negligible). I also consider the lifting down force negligible (measured to be around less than 1% the kart weight).
The steps I was following to find out the resistance force are the following:
I check the graph and wrote few +/- accurate points (speed in km/h, time s) contained in the graph. I got (115, 0) (80, 4) (60, 10) (40, 20).
I am going to consider the resistance force Fr= Frolling resistance +Drag = Pα*Zβ*(a+b*v+c*v2) + 1/2*ρ*CD*A*v2. I used the SAE J2452 for the rolling resistance (where v is in km/h). I am considering P, α, Z, β, a, b, c constant. Therefore, I ended up with a Fr = c1+c2*v+c3*v2 (v in km/h, and time in s)
My objective then is to find the constants c1, c2, and c3, using the graph points I showed before.
since the kart is decelerating only by the resistance force Fr, then I know that the deceleration -a = Fr/m
and a=dv/dt, therefore dv/dt = -(c1+c2*b+c3*v2)/m → dv/(c1+c2*b+c3*v2) = -dt/m →
∫dv/(c1+c2*b+c3*v2) = -∫dt / m
the ∫dv/(c1+c2*b+c3*v2) would be between v0 = 115 and v
the ∫dt would be between t0 = 0 and t
The integration of ∫dv/(c1+c2*v+c3*v2) is a very annoying one :
6acee4bafd48d80a2c6f683804e3105d07eb1010
if 4ac-b2 >0 I obtain the solution
-t/m = 2/√(4*c3*c1-c22) * arctg [(2*c3*v + c2) /√(4*c3*c1-c22)] - 2/√(4*c3*c1-c22) * arctgh [(2*c3*115 + c2) /√(4*c3*c1-c22)]
if 4ac-b2 <0
Similar but with the Ln.
When I try to resolve the function v (t) using excel solver...it cannot converge into any solution.
Could somebody help me finding a way to solve the problem?
I have other ideas to calculate the Resistance torque/Force, but it would required a torque transducer that would complicate the design of the vehicle.
Excuse me if I had any mistake or if the formulas are not very well explained. it isn't easy to write those formulas in the forum.
It's a good question. This is not a full answer, but I think you made an error or a typo in
Pablo87 said:
(c1+c2*b+c3*v2)
Shouldn't it be (c1+c2*v+c3*v2) ?
Hi Anorlunda,
Thank you, yes it was a typo but only here at the forum, the (c1+c2*v+c3*v2) is the correct polynomial I used in the problem.
Regards,
Pablo
Here's how I measured the drag and rolling resistance of my truck: https://ecomodder.com/forum/showthread.php/coastdown-test-06-gmc-canyon-20405.html. I used a simpler model, where total drag = fixed rolling resistance plus a speed squared term for aerodynamic drag. It solved easily because I was fitting only two coefficients to a much larger number of data points, and the data points went down to zero speed.
When fitting an equation to data, several conditions must be met to get good results:
1) Enough data points. More is better.
2) Data must cover a wide enough speed range. If you are fitting a curve with a quadratic term, you should have speed data down to zero speed.
3) Noise level must be low enough.
Likes berkeman and anorlunda
Here's an empirical method from Bosch Automotive Handbook 4th ed. (p.331):
Empirical determination of coefficients for aerodynamic drag and rolling resistance
Allow vehicle to coast down in neutral under windless conditions on a level road surface. The time that elapses while the vehicle coasts down by a specific increment of speed is measured from two initial velocities, ##v_1## (high speed) and ##v_2## (low speed). This information is used to calculate the mean deceleration rates ##a_1## and ##a_2##. See the following example.
The example is based on a vehicle weighing ##m## = 1450 kg with a cross section ##A## = 2.2 m².
The method is suitable for application at vehicle speeds of less than 100 km/h.
1st trial (high speed)
Initial velocity: ##v_{a1}## = 60 km/h
Terminal velocity: ##v_{b1}## = 55 km/h
Interval between ##v_a## and ##v_b##: ##t_1## = 6.5 s
Mean velocity: ##v_1 = \frac{v_{a1} + v_{b1}}{2}## = 57.5 km/h
Mean deceleration: ##a_1 = \frac{v_{a1} - v_{b1}}{t_1}## = 0.77 km/h/s
2nd trial (low speed)
Initial velocity: ##v_{a2}## = 15 km/h
Terminal velocity: ##v_{b2}## = 10 km/h
Interval between ##v_a## and ##v_b##: ##t_2## = 10.5 s
Mean velocity: ##v_2 = \frac{v_{a2} + v_{b2}}{2}## = 12.5 km/h
Mean deceleration: ##a_2 = \frac{v_{a2} - v_{b2}}{t_2}## = 0.48 km/h/s
Drag Coefficient
$$C_d = \frac{6m(a_1-a_2)}{A(v_1^2 - v_2^2)} = 0.36$$
Coefficient of rolling resistance
$$f = \frac{28.2(a_2 v_1^2 - a_1 v_2^2)}{1000(v_1^2 - v_2^2)} = 0.013$$
Thank you for the responses!
jrmichler, Not sure why I didn't think about a polynomial regression, you just solved my issue right away!
jack action, Thank you! I didn't know about this empirical solution. It will be handy to compare it with a polynomial regression. Maybe I should check the bosh handbook, since its quite inexpensive
Likes jrmichler and berkeman
