Grad. School in Physics w/ BA in Romance language
Applying to a physics graduate program with a BA in Romance Languages from NYU presents significant challenges. Most programs require an undergraduate degree in physics or a closely related field, such as engineering physics or physical chemistry. While some schools might consider applicants with different backgrounds, this is rare and typically reserved for exceptional candidates. The GRE is generally required by many institutions in the U.S., but it cannot substitute for the necessary physics coursework. Prospective students without a physics background will likely need to return to undergraduate studies for two to three years to complete the required prerequisites. Independent study in physics may be beneficial, but it is unlikely to compensate for a lack of formal education in the field.
chinablue
How would one apply to a physics graduate program when they have a BA in Romance Languages from NYU?
Are prerequisites specific to each school?
I assume a GRE is required for all schools.
Does one need an undergraduate degree in Physics?
Any advice along these lines is greatly appreciated.
An undergraduate degree in physics is a prerequisite for most undergraduate programs. Some people are accepted with degrees that are close such as engineering physics or physical chemistry or hybrid degrees.
Given that a BA in romance languages has little if any overlap with a standard undergraduate physics curriculum, the only way to get into physics graduate school is to return to undergraduate study for a few years and earn a second degree.
The GRE is not required for all schools, but it is for most in the USA. And for what it's worth, it's not a substitute for an undergraduate degree. It's more of a means of partially compensating for the different levels of rigor and difficulty at the many different schools out there.
Nominally they say you will need a STEM undergraduate degree...but I suppose for an outstanding applicant they might consider other degrees. I have heard anecdotes of people who got into PhD programs without even having done an undergrad. These would be extreme snowflake superstar cases, though.
Now, as to whether you are an outstanding applicant. Most likely your undergrad did not require you to do any physics at all, and if you did do it, it was for an elective.
I don't know your background...have you ever taken any physics courses?
Yeah, that won't work at all. They won't accept you and you'd be a world of hurt if they did. (unless you have maybe done some major level of independent study on the side and have a particular major genius for physics in some out of the ordinary way) Almost certainly you'll need to go back to undergrad for a few years (probably 2 or 3, unless there is a lot you've left out of your story and you've already taken a considerable number, but perhaps just shy of a dual major or something).
Hey, I am Andreas from Germany. I am currently 35 years old and I want to relearn math and physics. This is not one of these regular questions when it comes to this matter. So... I am very realistic about it. I know that there are severe contraints when it comes to selfstudy compared to a regular school and/or university (structure, peers, teachers, learning groups, tests, access to papers and so on) . I will never get a job in this field and I will never be taken serious by "real"...
Yesterday, 9/5/2025, when I was surfing, I found an article The Schwarzschild solution contains three problems, which can be easily solved - Journal of King Saud University - Science ABUNDANCE ESTIMATION IN AN ARID ENVIRONMENT https://jksus.org/the-schwarzschild-solution-contains-three-problems-which-can-be-easily-solved/ that has the derivation of a line element as a corrected version of the Schwarzschild solution to Einstein’s field equation. This article's date received is 2022-11-15...
