How is Mechanical Energy Conserved in a Gravitational System?
The discussion focuses on deriving the conservation of mechanical energy in a gravitational system, specifically for a point particle influenced by gravity. The derivation begins with Newton's second law and involves forming a dot product with velocity, followed by integration over time. The left side of the equation represents gravitational potential energy changes, while the right side reflects changes in kinetic energy. Ultimately, the equation shows that the total mechanical energy, represented by gravitational potential energy and kinetic energy, remains constant throughout the motion. This confirms that mechanical energy is conserved in a gravitational system.
decamij
I am in grade 12 physics, and i have to practice equation proofs. I am currently studying work, kinetic energy, springs, and potential energy (gravity and elastic).
Does anyone have a good proof?
Proof of what?
Your question is much too vague..
Sorry, i mean proving an energy-related equation.
Which of them?
Specifics, please.
i know its a simple equation, but i suck at proofs.
how about the general equation for gravitational potential energy?
Ok, I'll derive the conservation of mechanical energy for you, in the case of a point particle under the influence of the force of gravity.
I write Newton's 2.law in vector form:
-mg\vec{j}=m\vec{a}
where \vec{a}=\frac{d^{2}\vec{x}}{dt^{2}} is the acceleration, and
\vec{x}(t)=x(t)\vec{i}+y(t)\vec{j}
and the velocity is given by:
\vec{v}=\frac{d\vec{x}}{dt}
We also have:
\vec{a}=\frac{d\vec{v}}{dt}
1. Form the dot product
between \vec{v} and Newton's 2.law:
-mg\frac{dy}{dt}=m\frac{d\vec{v}}{dt}\cdot\vec{v}
2. Integrate this equation between 2 arbtriray points of time:
\int_{t_{0}}^{t_{1}}-mg\frac{dy}{dt}dt=\int_{t_{0}}^{t_{1}}m\frac{d\vec{v}}{dt}\cdot\vec{v}dt
3. The left-hand side is easy to compute:
\int_{t_{0}}^{t_{1}}-mg\frac{dy}{dt}dt=-mgy(t_{1})+mgy(t_{0})
4. We note the identity:
\frac{d\vec{v}}{dt}\cdot\vec{v}=\frac{d}{dt}(\frac{\vec{v}^{2}}{2})
where \vec{v}^{2}\equiv\vec{v}\cdot\vec{v}
5. Hence, the right-hand side in 2.) may be computed:
\int_{t_{0}}^{t_{1}}m\frac{d\vec{v}}{dt}\cdot\vec{v}dt=\frac{m}{2}\vec{v}^{2}(t_{1})-\frac{m}{2}\vec{v}^{2}(t_{0})
6. Collecting insights from 3. and 5., 2. may be rewritten as:
-mgy(t_{1})+mgy(t_{0})=\frac{m}{2}\vec{v}^{2}(t_{1})-\frac{m}{2}\vec{v}^{2}(t_{0})
7. Or, rearranging 6., we gain:
mgy(t_{1})+\frac{m}{2}\vec{v}^{2}(t_{1})=mgy(t_{0})+\frac{m}{2}\vec{v}^{2}(t_{0})
8. Or, noting that t_{1},t_{0} were ARBITRARY, every mechanical energy amount must remain the same at all times, so we get, by eliminating the specific time parameter:
mgy+\frac{m}{2}\vec{v}^{2}=K
where K is some constant for the whole motion.
That is, the mechanical energy is conserved for the particle
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
I passed a motorcycle on the highway going the opposite direction. I know I was doing 125/km/h. I estimated that the frequency of his motor dropped by an entire octave, so that's a doubling of the wavelength. My intuition is telling me that's extremely unlikely. I can't actually calculate how fast he was going with just that information, can I? It seems to me, I have to know the absolute frequency of one of those tones, either shifted up or down or unshifted, yes? I tried to mimic the...
