Graph F1CosX & F2CosX2, F1Sinx & F2Sinx2 Force Vectors
  • Thread starter Thread starter rasikan
    Graph
To draw the force vectors F1 and F2, first define their magnitudes and angles: F1 is 100 at 20 degrees and F2 is 200 at 30 degrees. Establish a coordinate system, typically the x-y axis. For F1, calculate its components as F1 = (100cos20, 100sin20) and plot the point accordingly. Repeat the process for F2 to visualize both vectors as arrows originating from the origin.
rasikan
F1Cosx and F2CosX2 and
F1Sinx and F2Sinx2
I need to draw each force vector as an arrow ?
how do I do that?
You need to tell us what F1 and F2 are before we can be any help. Without definitions, these are no more vectors than I am a top hat.
oky, f1=100 x1=20degree
and f2 200 x2=30 degree
Well, pick a coordinate system (say the x-y axis). Then the force F1=(100cos20, 100sin20). Since these are just numbers, you can plot the point (100cos20, 100sin20). Join this point to the origin, and you have your force vector. Similarly for F2
Thread moved from Advanced Physics to Intro Physics.
