Graph of energy against distance
  • Thread starter Thread starter arv88
    Energy Graph
The discussion centers on the graph of kinetic energy against distance for a book sliding across a table with friction. It is established that the graph will show a linear decrease in kinetic energy from the initial value to zero, represented by a straight line with a constant negative gradient. The vertical intercept corresponds to the initial kinetic energy, while the horizontal intercept indicates the distance the book slides before stopping. Participants also inquire about the relationship between energy, speed, and time, questioning if the gradient remains constant in those cases. The conversation emphasizes the importance of demonstrating effort in solving such problems, as it was moved to a homework forum.
arv88
MODERATOR'S NOTE: THIS WAS MOVED FROM GENERAL PHYSICS TO HOMEWORK FORUM, SO THERE IS NO TEMPLATE
Suppose a book is given a force F across a table with with friction. It will have an initial velocity v until it comes to rest due to friction. Does anyone know what will be the graph of kinetic energy against distance?
Since the force of friction is constant, won't it just be a decreasing line from the initial value to zero?
Do you mean a straight line with a constant negative gradient, is there an equation for this?
Yes, of course. But this looks like a homework problem, so there are details profs leave to the diligent student.
The vertical intercept will be (0, Ei), where Ei is the initial kinetic energy.
The horizontal intercept will be (d, 0), where d is the distance the book slides.
Figure out Ei and d, and then figure out the equation of the line from the two points.
Likes arv88
Alright, thanks, just for additional info, is the variation of the energy against speed and time the same as well, that is a constant negative gradient?
If this is not a homework problem, it like a homework problem, and should be in the homework forum. I'm moving it. Also, OP, you have shown no effort to solve this problem. Please see the PF rules and guidelines.
Chet
