What is the Solution for x When \( (4+3x)(6+3x) = 24 \)?
  • Thread starter Thread starter feod2003
    Graphing
The equation \( (4+3x)(6+3x) = 24 \) represents a quadratic function, which can be graphed to find intersections with the line \( y = 24 \). One user mentions that the vertex of the parabola is approximately at \( x = -1.7 \) and \( y = -1 \). Another suggests using a graphing application on a computer, hinting at Maple 8 for graphing purposes. A simpler method is proposed by expanding the equation to \( 9x^2 + 30x = 0 \), which can be factored and solved without a calculator. The discussion emphasizes both graphical and algebraic approaches to solving the equation.
feod2003
Graphing calc. died :( i need help
could some 1 but this in a calc and tell me the intersection when y is 24?
(4+3x)(6+3x)=24
thanks :shy:
according to my calculator (just started using it a few days ago), it's a parabola (sp?) and the vertex is about x = -1.7, y = -1. that's just with me using the trace function (i don't know how to get the vertex the normal way). hope this helps.
~Amy
~Amy
did you put (4+3x)(6+3x) into y1, and 24 into y2, after that make window bigger than 2end trace 5, then you get it.
Well, you obviously are sitting at a computer if you can post on PF that your graphing calculator died. Quiz question -- what application on your PC can be used for graphing? Hint -- it rhymes with Extra Large.
hm..sounds like Extra Large...Maple 8!
(4+3x)(6+3x)=24
thanks :shy:
Why would you need a calculator of any kind to do that? Multiply it out: 9x2+ 30x+ 24= 24 so 9x2+ 30x= 0. That's easy to factor and solve.
