Creating Fun Graphs with a Graphing Calculator: Tips and Tricks
The discussion revolves around a project requiring the creation of a picture using a graphing calculator, specifically aiming to draw a smiley face. The original poster, Jamond, shares several equations he has used but seeks additional formulas for different images. Participants suggest that instead of simply providing equations, Jamond should clarify the type of picture he wants to create for more tailored assistance. One user mentions successfully creating a butterfly using basic equations and encourages using simultaneous graphs for better results. The conversation emphasizes collaboration and problem-solving rather than simply giving answers.
jamondperry
Hey Guys,
In PreCalculus, today, I received a fairly difficult project -- probably not as hard as you would think, but I do need help. We are asked to create one picture on our Graphing Calculators. I have done about 11 so far, but none are as I like them.
This is what I put into the Y Values:
Y1= Ö(81-X )
Y2= -Ö(81-X2)
Y3= Ö(4-(X+3)2)+3.7
Y4= Ö(4-(X-3)2)+3.7
Y5= -Ö(1-X2)
Y6= -Ö(16-X2)-2
Y7= -Ö(1-(X+3)2)+3
Y8= -Ö(1-(X-3)2)+3
Y9= -.7abs X+12
*Note: The Ö symbol stands for the square root symbol. The big 2s at the ends of the Xs stands for "squared". I couldn't find a way to make them smaller.
Here are my window values:
Xmin= -12
Xmax= 12
Xscl= 1
Ymin= -10
Ymax= 15
Yscl= 1
This should produce a smiley face. Can you show me some of your graphics and formulas you have used? I would greatly appreciate it!
Thanks so much; I really really need this! This is an urgent question.
Thanks,
Jamond
I can't tell what you're asking us to help you with. Are you having trouble putting those equations into your calculator? Are you trying to come up with your own equations to make a smiley face?
- Warren
No sir.
I know how to compute those formulas in my calculator. I know it is a smiley face, because I put it into see that it was!
Anyway, I was giving you an example of what I was talking about. I wanted you all to give me some formulas for another picture. All the other pictures, I have come up with are not to caliber.
Thanks,
Jamond
Well, if the objective is to create a picture, why don't you write a program to create the desired picture? My sugestion: a fractal (eg. Koch's snow flake or one created by you).
To find information about fractals, TI-83 algorithms and other stuff...use google.
So... I take it your teacher gave you the "smilie face" equations, then asked you to find another set of equations to draw another kind of picture.
Next, you came here to see if someone would do your project for you by simply providing you such a set of equations.
That's not how things work here -- we do not simply give you answers, and we're not going to do your project for you. Perhaps you should tell us what you're trying to do -- what kind of picture you're trying to draw, and what you're stuck on -- and we can give you some help.
- Warren
Well I created a butterfly many times...
I used in the normal window, (-10 to 10 or view standard)
Edited: I'm not gonig to give you my equations but they're simple...2 quads, 2 cubes, 4 logs.
And it works...pretty good. Especially if you graph them in simultaneous...that should impress him.
ALso...using 2 sin and 2 cos equations you can make a mini chain...
pretty simple but maybe it helps.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
