Solving Grating Resolution Homework for Skyscraper Distance
To determine the distance from the skyscraper where the two blue lights can be resolved, the resolution limit is calculated using the formula θ=1.22λ/D, where λ is the wavelength and D is the pupil diameter. Given the blue light's wavelength of 475 nm and a pupil diameter of 2 mm, the minimum angular separation can be derived. The discussion highlights that the red lights cannot be resolved due to their longer wavelength of 650 nm, indicating a greater diffraction limit. Ultimately, the conclusion is that the observer is approximately 10 km away from the skyscraper, based on the calculations related to resolving power.
Gee Wiz
Considering larger objects, a skyscraper has two tall antennae separated by 3 meters. Each antenna has one blue and one red light. You can resolve the two blue lights but not the red ones.
Assume that your pupils have a diameter = 2 mm at night, and that blue light's wavelength is 475 nm, while red light's wavelength is 650 nm.
Approximately how far are you from the skyscraper? (Also assume that you have 'perfect vision' limited only by diffraction.)
θ=1.22λ/D
Δλ/λ=1/(mN)
I know the answer is 10km, but I don't know how to get that. I was trying to find a way to determine the resolution requirement, or something like that.
There is a minimum angular separation that you can resolve two objects - it depends on the wavelength of the light and the diameter of the aperture. You should have some notes on this under "resolving power".
