Gravitation: Calculating Accel. Due to Gravity at 1.43x10^8 m
To calculate the acceleration due to gravity at a distance of 1.43 × 10^8 m above Earth's surface, the formula used is G*mE/r^2. The correct values for G (6.674E-11 m^3 kg^-1 s^-2), the mass of Earth (5.98E24 kg), and the radius (r) must account for the distance from the Earth's center, which is 1.43 × 10^8 m plus the Earth's radius (approximately 6.37 × 10^6 m). One participant initially calculated an acceleration of 0.0195 m/s^2 but later adjusted their understanding and recalculated to 0.0179 m/s^2, confirming the importance of accurately defining r. The discussion emphasizes the significance of correctly interpreting the distance in gravitational calculations.
gjax21
1.A satellites are placed in a circular orbit that is 1.43 × 10^8 m above the surface of the earth. What is the magnitude of the acceleration due to gravity at this distance
1.I used G*mE/r^2
1. Got an answer of .0195m/s^2 I think I get this and have no idea why it is wrong.
What values did you use for G, mE, and r?
Is the satellite 1.43\cdot 10^8 m above the surface of the earth, or 1.43\cdot 108 m above the surface of the earth?
Using the former, I got a result only slightly different from yours. Remember that the r in that formula is the distance between the center of the Earth and the satellite, not from the surface of the Earth and the satellite.
O thax I didn't realize it was saying above the surface. I meant 1.43x10^8. :)
using 6.674E-11 for G
Mof earth= 5.98E24
r=149380000
I get an answer of .0179, does that check out?
Got it thax
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
