Gravitation: launching a craft out of the solar system.
Wavefunction
Let's suppose that we wanted to launch a spacecraft of mass m out of the Solar System.
a) If we want to launch the spacecraft directly from Earth, what boost Δv would be required
and what direction relative to the Earth's velocity about the Sun would this boost be pointed
in?
b) Now let us assume that we wanted to save energy (reduce the magnitude of Δv) by using a
gravitational slingshot off of a single planet. Assume that all the planets are on circular
orbits with the same orbital plane as the Earth, and for now assume that the planets are point
masses. Which planet would you choose and why? The necessary information about
planets is available on Wikipedia. What would be the magnitude and direction of Δv?
c) Real planets have surfaces, and bad things happen to spacecraft (and astronauts) that crash
into the surfaces of planets. Does this change your answer to part b of this problem? Why
might it?
E=\frac{1}{2}μv^2-\frac{GMμ}{r}=\frac{GMμ}{2a}; a=r_1+r_2
Part A)
Let E_p = \frac{1}{2}μ(v_p)^2-\frac{GMμ}{r_1}=\frac{GMμ}{r_1+r_2} be the energy at the periapsis.
Then the corresponding magnitude of the velocity of the spacecraft at periapsis is: v_p = \sqrt{2GM(\frac{1}{r_1}-\frac{1}{r_1+r_2})}
Also the magnitude of the velocity around the 1st circular orbit is : v_1=\sqrt{\frac{GM}{r_1}}
So in order to boost from the circular orbit around Earth to the transitional elliptical transfer orbit requires v_1+Δv=v_p or Δv=v_p-v_1
Thus Δv = \sqrt{\frac{GM}{r_1}}(\sqrt{\frac{2r_2}{r_1+r_2}}-1)
As r_2 →∞ , Δv→\sqrt{\frac{GM}{r_1}}(\sqrt{2}-1)
Now for the direction: (v_p)^2 = \vec{v_p}\cdot\vec{v_p} = \vec{v_1}\cdot\vec{v_1}+\vec{Δv}\cdot\vec{Δv}+2\vec{v_1}\cdot\vec{Δv} which is clearly maximized for Δv in the same direction as v_1
(everything in part A makes sense to me, but I want to be sure I didn't make any careless errors)
Part B) I know I need to minimize the first expression for Δv with respect to r_2 i.e \frac{d}{dr_2}Δv=0 and then verify that that second derivative of this expression evaluated at the extrema is positive. Then I need to check which planet fits the radial orbit I find from minimizing Δv wrt r_2. However, before I do this Is my expression for Δv correct?
Part C) I personally don't see any reason why the planets having surface areas affects anything in part B, but just because I don't see a reason it doens't mean there isn't one. Any clues on this one?
Thank you in advance!
Actually I just realized the answer to part B) lies in the gravitational slingshot: in the reference frame where the planet is still the initial velocity of the craft is equal to the final velocity (well the magnitudes are equal, not the directions) \|\vec{v_c}\|=\|\vec{v'_c}\|
If the craft moves along with the planet (which is moving at velocity v_p then \|\vec{v_p}+\vec{v_c}\|<\|\vec{v_p}+\vec{v'_c}\| so in order to minimize Δv I need to choose a planet with a high orbital velocity about the sun. So in the approximation that the planets are points masses Mars is the best choice.
It also just occurred to me that if I were to use the result from part b the craft would crash directly into Mars since Mars is not a point mass and has surface area so I would need to use a more ecentric elliptical orbit in order to properly use the sling shot i.e increase the semi-major axis by increasing r_2
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
