Calculating 25% of Gravity at Height
  • Thread starter Thread starter RoughRoad
    Gravitation
To determine the height at which gravity falls to 25% of its value at Earth's surface, the equation g = GM/R^2 is used. By setting the new gravitational acceleration g' to g/4, it is derived that R' (the new distance from the Earth's center) equals 2R. Since the question specifies height above the Earth's surface, the final answer is R, indicating the height is equal to the radius of the Earth. The discussion confirms the method used is correct, and the textbook answer aligns with the calculations. The problem-solving process emphasizes collaboration and validation of results.
RoughRoad
At what height will the acceleration due to gravity will fall to 25% that of the Earth's surface?
g= GM/R^2
RoughRoad said:
g= GM/R^2
Good.
RoughRoad said:
You're missing this.
g=GM/R^2 or R^2=GM/g..
let g' be new value of g which is fall in 25%..
therefore 25g/100= g' or g'=g/4
R' be the new distance from surface of Earth than,
R'^2=GM/g'
as g'=g/4 therefore
R'^2=4GM/g
as GM/g= R^2 therefore R'^2=4R^2
R'^2= (2R)^2
R' = 2R
therefore answer is 'R' above surface of earth. As 2R is distance from center
Since they asked for the 'height' I would assume they want from the surface and not the distance from the center.
But your method is correct.
The answer given in my textbook is R. And I have worked it out with my friend and now I got the answer. But thanks to both of you for helping me solve this problem.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
