How Does Height Above Earth Affect Satellite Weight?
The weight of a satellite decreases with height above the Earth due to the weakening gravitational force. At 12.8 million meters above the Earth's surface, the standard gravitational acceleration of 9.81 m/s² is not applicable. Instead, the gravitational force can be calculated using the formula F = GMm/d², where G is the gravitational constant, M is the Earth's mass, m is the satellite's mass, and d is the distance from the Earth's center. This approach provides a more accurate weight for the satellite at that altitude. Understanding the impact of altitude on gravitational force is crucial for precise calculations in satellite dynamics.
Arooj
What is the weight of a 200 kg satellite 12.8 * 10^6 m above the surface of the Earth.
F = mg
F=200 (9.81)
F = 1962 N
I thought this was a basic weight problem, but I was confused on whether the height above the Earth affects the weight.
The gravitational force gets weaker as you go further out from the center of the Earth. The g = 9.81 value will not be accurate. You could use the basic gravitational force formula F = GMm/d² (M=mass of Earth, m = mass of satellite, d = distance from center of Earth to center of satellite) or you could use the F = mg with g = GM/d².
