Gravitational Potential energy question
The discussion centers on calculating various energy values for a satellite in orbit, including gravitational potential energy, kinetic energy, binding energy, and the energy required for escape velocity. The gravitational potential energy was calculated as -3.13 x 10^10 J. There is confusion regarding the radius needed for kinetic energy calculations, with the Earth’s radius of 6000 km mentioned. Participants clarify that the Schwarzschild Radius is not applicable to this problem. The focus remains on correctly applying the relevant equations to find the required values.
MasterAsia
a 5.00 x 10^2 kg satelilite is in circular orbit 2.00 x 10^2 km above Earth's surface. calculate
a) gravitaional potential energy which i got, which is -3.13 x 10^10 J
b) kinetic energy of the satellite
c) binding energy of satellite
d) the percentage increase in launching energy required for the satellite to escape earth
2GM/c^2
Eg = - GMem/re
v = sqroot GM/r for the velocity then using the equation 1/2mv^2 to get the Ek, but i don't know how to get the radius so i can plug it into the Ek equation.
The Earth has a radius of 6000 km.
How did you get the gravitational potential without knowing the radius?
2GM/c^2
That's Schwarzschild Radius. That is not a relevant equation for this problem.
