Why do objects always revolve around each other in space?
In summary, Einstein's theory of general relativity explains why objects always move in space-time, even if they're not in motion. If you're not in motion, you're still moving through space-time.
Stephanus
1,316
104
Dear PF Forum,
I have a confusion about gravity. And frankly I don't know if this question belongs to this sub forum (cosmology, general physic?).
Gravity attracts object - Newton
Gravity curves space time - Einstein.
Why we revolve around a massive object?
Because that massive object curves space and we try to travel straight? So we revolve that massive object because that object curve space around it and we think that the curve is straight line?
But what if we don't travel. What if we just sit still and there's a massive object coming toward us. Would we still revolve that object once we are in its gravitational field? I think we are ALWAYS in its gravitational field no matter how far that object but its force (if we can call graviti, force) would be very weak.
A: So from our point of view.
Whoaa, there's a big object coming toward us, but why would we revolve around it. We just sit still right?
B: From that massive object point of view
Hey, there's a little thing coming toward me, well once it is in my gravitational field, it will revolve around me.
So no matter how the small object always revolves the bigger object right? And as I read somewhere the bigger object also revolves that small object but in a less curve.
So my conclusion is this.
In space time
A: Do we always move in time? I think so, we are getting older aren't we?
B: Do we ALWAYS MOVE in space? Does everything in this universe always move in space?
C: If B is true, is that why every object always revolves other object either bigger or smaller, because everything ALWAYS MOVE in space?
Thank you very much.
This is not correct. The correct statement is "because that massive object curves space-time".
It is not a straight line in space, it is a straight line in space-time. You are changing your time coordinate and thus traveling in space-time. There is no such thing as "not traveling", it would correspond to something existing only at one event.
Likes Stephanus
Orodruin said:
This is not correct. The correct statement is "because that massive object curves space-time".It is not a straight line in space, it is a straight line in space-time. You are changing your time coordinate and thus traveling in space-time. There is no such thing as "not traveling", it would correspond to something existing only at one event.
Okay, that we travel in time I can understand that. I'm gettting older 5 minutes from my first post. But does EVERYTHING ALWAYS MOVE in space also?
There is no way of defining "move in space" without referring to a particular coordinate system. You can always find a coordinate system in which an object moves, just as you can always find one where it stands still.
Likes Stephanus
We still "travel" through time.
Edit: i am way too slow today!
I'm baffled by this post. We wouldn't revolve around the big object: it would smash into us, surely?
Einstein noted that as we sit still on Earth in its frame of reference, we are, nevertheless, traveling through time at the speed of light. Source: Brian Greene's Fabric of the Cosmos.
Is it correct to infer that Movement through space slows our movement through time?
[Moderator's note: edited to delete off topic content.]
Likes Stephanus
Be cautious about Brian Greene's popularizations. He sometimes says "This is how it works" when it would be more accurate to say "This is NOT how it works, but it's easy to understand and won't be too misleading as long as you don't take it too seriously". There's nothing wrong with this as long as you understand what you're getting and the limitations of the explanation - but people are often confused when they try to carry the explanation too far.
Writers like Greene are one of the reasons why Physics Forums has a rule about acceptable sources.
Likes Sookie, ComplexVar89 and PeterDonis
Why should it. If, say, there is a massive object coming toward us, but pass by say 1 million KM, would we "follow" it and eventually revolve around it?
No, not unless you by some other means accelerate to enter orbit around the object. Otherwise it would simply slingshot you.
https://en.m.wikipedia.org/wiki/Gravity_assist
Likes Dale
What would moving slowly through time mean? That when I get to Monday you are still only on Sunday? That seems rather silly. I'm afraid that Nugatory has a point - Greene often over-simplifies things to the point of being wrong, and that's what's going on here.
What Greene has done is pick a particular coordinate system (conceptually, filled space with a regularly spaced array of clocks that he has synchronised by some method). He can always do this so that the four velocity of a chosen object is parallel to the direction he's chosen to call time and all his clocks are stationary with respect to it. Any other four velocity has a smaller component in the direction he's chosen to call time, which means that it's clocks will advance slower compared to the array of clocks Greene previously synchronised. But since Greene has a lot of freedom to choose what he calls "synchronised", that's just an artifact of his (entirely reasonable) choice.
So you're saying that if we don't accelerate it doesn't slingshot us, it could just pass us not necesserily hits us?
This is my respons to
It might just passes us right.
Perhaps I should add
Movement through space [wrt, with respect to other body] slows our clock [wrt other body]
The only thing that you would feel is acceleration or gravity if you're bound on solid object such as your chair (which is bound to your floor which is bound to your house foundation which is bound to earth).
You'll never feel that you move! (Mentor/staff/advisor please correct me)
And you can never realize that your clock runs slow,
How can you?
Your clock runs slow, but your brain runs slow, too. You can't realize it, and everything around you, your heart beat, your digesting system, your chemical reaction, your music player, everything runs slow. You can't realize it can you. But if you see other thing that travels wrt you, you'll see its clock runs slow, too
More precisely, "slows our clock with respect to an array of clocks synchronised by Einstein's method (or many others but not all) and stationary with respect to the other body".
Thanks so much for your reply. As much as I like Greene's books, I find anything he does on TV unwatchable. Even to my layperson's limited knowledge, I see him consistently over-dramatizing things like quantum weirdness and special relativity. I will approach his books with more skepticism even though I don't have the knowledge base to criticize him.
[Mentor's note: Some text discussing another thread has been removed from this post because it is off-topic here]
No, this is not what I said. I said if you do not have other means of acceleration than the gravity, you will not enter orbit.
@Stephanus
Consider the Newtonian limit. If you are only under the influence of gravity then you will either travel in an elliptical path if you are in orbit or a hyperbolic path if you are not. There simply is not a gravity-only solution which goes from moving in a straight line wrt each other to revolving around each other.
When you get strong gravity in GR that can change, like you will not depart on a hyperbolic path if you cross the event horizon of a bkack hole.
Dale said:
@Stephanus
In other words one needs to apply an acceleration to enter an orbit... this may be easier to grasp by considering the opposite - that one must apply an acceleration to exit an orbit.
Likes Dale
Okay, since we are in the heat of it, although this might be off topic. I'd like to ask anyway.
At the picture above,
1: Is there a chance that Red and Blue will collide?
2: Red and Blue must collide?
3: Is there a chance that Red and Blue will revolve each other?
4: Red and Blue must revolve?
Below
5: Is there a chance that Red and Blue will collide?
6: Red and Blue must collide?
7: Is there a chance that Red and Blue will revolve each other?
8: Red and Blue must revolve?
Thanks for any answer.
Add: Below
Red and Blue in a straight line
Below
Add: Below
What do you think? You've been studying physics for long enough now. What do you have to show for it? :smile:
I think at the picture above, could have missed, could have hit.
But...
But...
Draw a diagram to scale of two billiard balls in space on a near collision course; and the same diagram to scale of two planets on a near collision course. Let's assume the billiard balls miss each other. Will the planets miss each other? Or, with gravity does size matter?
In other words, you didn't give nearly enough information to figure out what will actually happen. But in both cases, it looks like you don't intend for the incoming small object Blue to already be in orbit about the large object Red. If that's the case, then no amount of free-fall motion will put Blue into orbit about Red; it will either hit Red, or fly past and escape. That is what previous posters have been trying to tell you.
The original question has been sufficiently answered. Thread closed.
Related to Why do objects always revolve around each other in space?
1. What is gravity?
Gravity is a force of attraction between objects with mass. It is responsible for keeping planets in orbit around the sun and objects on Earth from floating away into space.
2. How does gravity work?
Gravity works by pulling objects towards each other. The strength of the gravitational force between two objects depends on their masses and the distance between them. The larger the masses and the closer the distance, the stronger the force of gravity.
3. What is relative motion?
Relative motion is the concept that an object's motion can appear different depending on the observer's perspective. This is because an observer's motion and the object's motion are always relative to each other. For example, a person standing on a moving train will see a person on the ground as moving in a different direction than they actually are.
4. How does gravity affect relative motion?
Gravity can affect relative motion by influencing the acceleration and velocity of objects. For example, the gravitational pull of the Earth causes objects to accelerate towards the ground, which can change their relative motion to an observer.
5. Can gravity and relative motion be explained by Einstein's theory of relativity?
Yes, Einstein's theory of relativity explains how gravity and relative motion are related. According to the theory, gravity is not a force but rather a curvature of space and time caused by the presence of massive objects. This curvature affects the motion of objects, leading to the observed effects of gravity and relative motion.
