Gravity, velocity time and distance problem
A rock dropped from a height of 180 meters falls under the influence of gravity at 9.81 m/s². The velocity of the rock when it hits the ground is calculated using the formula v = √(2gh), resulting in approximately 59.43 m/s. The time taken for the rock to fall is derived from the relationship t = v/g, yielding about 6.1 seconds. The discussion clarifies the derivation of the velocity and time equations, emphasizing that gravity accelerates objects at a constant rate. Understanding these relationships is essential for solving similar physics problems.
-Physician
A rock from high of ##h=180m## goes down and the gravity is ##g=9.81\frac{m}{s^2}##.
Find for how much time did the rock fall down and the velocity of the rock.
##v^2=2gh##
##v=\sqrt{2gh}##
##t=\frac{v}{g}##
First of all we will find the velocity because, to find time we need the velocity so:
##v=\sqrt{2gh}=\sqrt{2χ9.81\frac{m}{s^2}χ180m}=
\sqrt{3531.6}=59.43 \frac{m}{s}##
##t=\frac{v}{g}=\frac{59.43\frac{m}{s}}{9.81\frac{m}{s^2}}=6.1s##
is that correct way to do it?
BTW. how to make the square root on formulas?
What you have done is correct. Be careful with your significant figures. You provide 4 significant figures for the velocity yet only use 3 for g.
I don't use formulas so I cannot help you there.
Thanks, but i have two more questions:
Where do we know that ##t=\frac{v}{g}##, if in formula of velocity ##v=√2gh## we don't have time ##t##?
and would gravity formula be ##g=\frac{v^2}{h}## or ##g=\frac{v}{t}## and ##v=gt##?
The parameter g is the acceleration of gravity in a free fall. In other words if you drop a ball, it accelerates toward the ground at a rate of 9.81 m/sec^2. The velocity attained during a free fall is (with no air drag)
v = gt
Rearranging,
t=v/g
As for v=sqrt(2gh), that formula can get derived a least a couple of ways.
For an object dropped with no initial velocity, the distance it falls is
h = 0.5 g t^2
But we know that
v = g t
so t = v/g
Substitute for t in the displacement equation
h = 0.5 g (v/g)^2 = 0.5 v^2/g
Therefore
v = sqrt(2gh)
The same formula can be derived from conservation of energy considerations.
got it now thanks!
