Greatest lower bound of Vector Space
iamalexalright
Prove:
The set S(V) of all subspaces of a vector space V is a complete lattice under set inclusion, with smallest element {0}, largest element V, meet
glb(S_{i} | i \in K) = \cap_{i \in K} S_{i}
and join
lub(S_{i} | i \in K) = \sum_{i \in K} S_{i}
(Btw, how can I write underneath a symbol instead of at the subscript position?)Solution:
I know there exists a glb and a lub since this is a complete lattice.
I'll start with the lub (least upper bound) and I'll try to show first that if S,T are subspaces of V then:
S + T = lub(S,T)
Let S,T be subspaces of V. Then there exist vectors s \in S and t \in T.
Since s,t \in V(since S and T are subspaces of V) then s + t \in V.
Since all vectors in S,T are in V (I think I'm being repetitive) then all vectors from S summed with all vectors from T is in V hence: S + T is a subspace of V.
Should be obvious that S + T is least upper bound of S and T (is this obvious)?
Since S + T is a subspace of V call it U. Let W be a subspace of V then:
W + U = (S + T) + U = lub{U,V}
You can repeat this to finally show that:
lub{S_{i} | i \in K} = \sum_{i \in K} S_{i}
I think I can show the GLB in the same way.
I know this isn't very robust and probably longer than what is needed (I'm only starting out writing proofs).
All correct, but there are two remarks I'd like to make:
No, I'm sorry, this is not obvious to me.
You say that you repeat this argument, but if you do so, you will only obtain the result for finitely many subspaces. I.e. you will obtain that
lub\{U_1,...,U_n\}=U_1+...+U_n
But I is infinite here. So this case must still be dealt with...
In fact, if you find the result for two factors S and T, then the argument will generalize to infinitely many factors. So focus on the result for two factors for now...
I know this isn't very robust and probably longer than what is needed (I'm only starting out writing proofs).[/QUOTE]
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
