Tomer
- 198
Confirm that the retarded potentials satisfy the Lorentz gauge condition.
\vec{A}(\vec{r}, t) = \frac{\mu_{0}}{4\pi}\int\frac{\vec{J}(\vec{r'},t_{r})}{R}d\tau'
V(\vec{r}, t) = \frac{1}{4\pi\epsilon_{0}}\int\frac{\rho(\vec{r'},t_{r})}{R}d\tau'
Where:
\vec{r}: position of measurement
\vec{r'}: integration variable (running on charge and current densities)
R = |\vec{R}| = |\vec{r} - \vec{r'}|
t_{r} is the retarded time: t_{r} = t - \frac{R}{c}
\vec{J}(\vec{r'},t_{r}) is the current density (estimated at the point \vec{r'} at the retarted time), and \rho(\vec{r'},t_{r}) is the charge density.Lorentz gauge means:
\nabla \cdot \vec{A} = -\epsilon_{0}\mu_{0} \frac{\partial V}{\partial t}
Now, Griffiths gives a rather lengthy hint containing different formulas that one could apply in order to prove this. But I found his method cumbersome and could not understand why it's necessary (he uses relations between primed and unprimed operators and eventually gets there). For me, my "straight-forward" method is simpler, but for some reason it doesn't work. I'd really appreciate your insights!\nabla \cdot \vec{A} = \frac{\mu_{0}}{4\pi}\int\nabla \cdot (\frac{\vec{J}(\vec{r'},t_{r})}{R}) d\tau' = \frac{\mu_{0}}{4\pi}\int [\frac{1}{R}\nabla \cdot \vec{J} - \frac{1}{R^{2}} \hat{R} \cdot \vec{J}]d\tau'
Meanwhile:
-\epsilon_{0}\mu_{0} \frac{\partial V}{\partial t} = - \frac{\mu_{0}}{4\pi}\int \frac{\partial}{\partial t} (\frac{\rho(\vec{r'},t_{r})}{R})d\tau' = - \frac{\mu_{0}}{4\pi}\int \frac{1}{R}\frac{\partial \rho}{\partial t} d\tau' = \frac{\mu_{0}}{4\pi}\int \frac{1}{R}\nabla \cdot \vec{J} d\tau'
Where in the last inequality I've used the continuity equation: \frac{\partial \rho}{\partial t} = -\nabla \cdot \vec{J}
So somehow the next equation should hold:
\frac{\mu_{0}}{4\pi}\int \frac{1}{R}\nabla \cdot \vec{J} d\tau' = \frac{\mu_{0}}{4\pi}\int [\frac{1}{R}\nabla \cdot \vec{J} - \frac{1}{R^{2}} \hat{R} \cdot \vec{J}]d\tau'
However, unless the integral containing \frac{1}{R^{2}} \hat{R} \cdot \vec{J} vanishes, this is obviously wrong. And I can't seem to prove it vanishes.
Am I doing something wrong? Is any step here false? THANK YOU!
Tomer
