Is Zn a group under addition modulo n?
  • Thread starter Thread starter roger
    Group
The discussion focuses on whether the set Zn of integers modulo n forms a group under addition modulo n, emphasizing the importance of the group axioms. Closure is highlighted as essential, meaning that the sum of any two elements in Zn must also be an element of Zn. Participants clarify that Zn typically consists of the integers {0, 1, 2, ..., n-1}, with addition defined as the remainder when the sum is divided by n. Associativity is explained through the property of addition in integers, which holds true in Zn as well. Understanding these concepts is crucial for proving that Zn satisfies the group axioms.
roger
Hi,
Firstly I am not sure what a group is, after being given the 4 group axioms.
I'm not sure what relevance ''closure'' has ?
and my question is : how to show that for every natural number,n, the set Zn of integers modulo n forms a group under addition modulo n ?
I appreciate any guidance.
Thankyou very much.
Roger
Mathematics news on Phys.org
If you are going to look at groups as separate objects themselves, then "closure" under the group operation is essential. For example, if a and b are members of the group G but a+ b isn't then we are faced with the question of just what do we mean by "a+ b" if we are only talking about G!
To prove that any collection of things with a given operation is a group, you need to show that the definition of "group", usually given as a collection of "axioms", is satisfied.
To show that "Zn of integers modulo n forms a group under addition modulo n" you first have to decide what things are in that set (there are, in fact, a few different ways of looking at this). Assuming that you mean {0, 1, 2,..., n-1} then you must show:
I) Closure: that if m and n are both integers between 0 and n-1 then 0+ (n-1) (mod n) is also an integer between 0 and n-1.
II) Associativity: that (m+ n)+r= m+ (n+ r) (mod n)
(This is not just moving parentheses. The operation is defined on two objects at a time (m+n)+ r involves quite a different calculation than m+ (n+r).)
III) Identity: that there exist one member of the set, O, such that n+O= n for all n in the set.
IV) Inverse: that for any x in the set, there exist a y such that x+y= O.
thanks Hallsoivy,
I don't actually know what the terms ''Zn of integers modulo n'' and '' addition modulo n" mean ?
and I am not sure how to find the elements of the set ?
and what is the difference in calculation for associativity exactly ?
What do you mean by this ?
roger said:
thanks Hallsoivy,
Then you do have a problem! The reason I asked about "deciding what things are in the set" is that there are a couple of different (but equivalent) ways of defining "Zn". The simplest is to take {0, 1, 2, ...,n-1} as the elements, then define "a+ b (mod) n" to be "the remainder when a+b is divided by n". For example, in Z5, the elements are {0, 1, 2, 3, 4}
4+ 4 (mod) 5 = 3 because 4+4= 8 and 8= 5+ 3. Notice that, although 8 is greater than 5, "8 (mod 5)" is one of {0, 1, 2, 3, 4, 5}. That's what we mean by "closure". We don't go outside the set we are looking at.
It should be clear that 0 is the group identity in Zn: n+ 0= n and since n is already less than n, you don't need to worry about the "mod" part.
What about "negatives" (additive inverse). If we were talking about Z5, 3+ 2= 5 which has remainder 0 when divided by 5 so 3+ 2= 0 (mod 5). What "x" gives 4+ x= 0 (mod 5)? (In other words, what x gives 4+ x= 5?)
Can you generalize that to any Zn?
Associativity comes down to this:
suppose we have some way of composing two elements of something we want to test for "groupiness", then there are two ways one can bracket the a priori undefined object fgh as (fg)h or f(gh) are the same so that the symbol fgh is unambiguous.
Example: additoin we all know that doing (2+3)+4 is the same as doing 2+(3+4)
Counter example: subtraction is not associative. We know that the symbol a-b-c is not strictly well defined in the sense that
(1-1)-1
and
1-(1-1)
give different answers.
The best way to show something is associative is to appeal to the fact that the objects you're composing are derived from some other group where we know associativty holds. In the case of mod n arithmetic we can use the fact that addition in the integers is associative (which is true by fiat) to conclude it passes down to associativity for Z_n
Note the subscript: it is important. Zn is striclty different from Z_n in a fundamental way in the standard usages of these terms. Zn is usually the set of (integer) multiples of n inside Z. This too is a group.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
