Group Theory: Ord(x) = Ord(g^-1xg)
The discussion revolves around proving that the order of an element \( x \) in a group \( G \) is equal to the order of the conjugate \( g^{-1} x g \). Participants explore the implications of this relationship and its connection to the orders of elements in group theory.
  • Participants discuss various attempts to prove the equality of orders, with some questioning the validity of certain steps in the original proof. There are mentions of using induction and contradictions to establish the relationship between the orders of \( x \) and \( g^{-1} x g \).
The discussion is ongoing, with participants providing hints and guidance on how to approach the proof. There is recognition of the need for careful reasoning regarding the orders of elements and the implications of their relationships.
Some participants note that the original proof may not hold in non-commutative groups and emphasize the importance of distinguishing between the order of an element and the conditions under which certain equalities hold. There is also mention of the need to consider the smallest positive integer for which \( x^n = e \) and how this relates to the conjugate element.
basil32
If x and g are elements of the group G, prove that |x|=|g-1xg|. Deduce that |ab| =|ba| for all a,b [itex]\in[/itex] G
I've written a proof but does not seem quite right:
if (g-1xg)n= xm then n must be equal m
g-nxngn = xm then
xngn =gnxm
xn =gnxmg-n
xm =g-nxngn
xn = gn(g-nxmgn)g-n
xn = xm
n = m
There's more than one thing wrong with that. The problems start with (g^(-1)xg)^n=g^(-n)x^ng^n. That's only true if the group is commutative. I'll give you a big hint. (g^(-1)xg)^2=(g^(-1)xg)(g^(-1)xg). What's that?
(g-1xg)2 = (g-1xg)(g-1xg) => g-1x2g
so by induction (g-1xg)n = g-1xng
and?
and?
Now it's your turn. Think about what order of x and order of g^(-1)xg mean. Show they are the same number.
g-1xng = e
xng=ge
xn = g.g-1
xn = e
Thanks.
basil32 said:
g-1xng = e
xng=ge
xn = g.g-1
xn = e
Thanks.
just because g-1xng = e, and xn = e, does NOT mean that |g-1xg| = |x|.
at best, it only shows that |g-1xg| divides |x| (assuming by n, you mean |x|).
you need to show that no smaller positive integer will work (this isn't that hard, try proof by contradiction).
then there's still part 2...
It is also, by the way, not true in a general group that is [itex]x^m= x^n[/itex], m= n.
right. an obvious example is in the multiplicative group of non-zero real numbers.
(-1)2 = 12 = 1, but -1 ≠ 1.
A bit of a blow. I thought I finished but apparently it requires much more careful thinking.
The choice of n is the smallest positive integer that xn=e. So any m < n would contradict this. What's to prove?
Prove that [itex](g^{-1} x g)^m = e[/itex] cannot happen for a positive integer [itex]m < n[/itex]. Use the fact mentioned earlier that [itex](g^{-1} x g)^m = g^{-1} x^m g[/itex] for any integer [itex]m[/itex] to derive a contradiction based on the assumption that [itex]1 \leq m < n[/itex] and [itex](g^{-1} x g)^m = e[/itex] both hold.
that n is, in fact, the order of g-1xg. we know no smaller m works for x, but g-1xg, isn't x, it's some other element of G, so you need to prove no smaller m will work for g-1xg.
suppose (as an imaginary example) that g-1xg = x2, and |x| = 4.
then g-1xg would have order 2, and so would still be e if raised to the 4th power since e2 = e.
do not confuse the statements xn = e, and |x| = n. this can get you into trouble. the second implies the first, but NOT the other way around.
you have to get used to this sort of thing, because often you will consider functions (homomorphisms) from one group to another f:G→H. if f is not 1-1 (and you will encounter such functions), than f will map several elements to the identity of H.
due to the nature of homomorphisms, it will be the case that if |x| = n, (f(x))n will be eH. but this does not mean |f(x)| = n.
so the map G→G given by x→g-1xg is special, it doesn't display this kind of behavior.
  • · Replies 24 ·
  • · Replies 26 ·
