Guass' Law (Conducting Cylinder)
The discussion revolves around calculating the x-component of the electric field at a specific point near two coaxial cylindrical conductors with given charges. The inner cylinder has a charge of +8 nC, while the outer cylinder has a charge of -16 nC. The user initially calculated the charge per unit length incorrectly as 0.8 nC instead of the correct value of 8 nC, which led to errors in their electric field calculations. After realizing the mistake, they corrected their calculations but expressed frustration with the online homework system, which had initially provided misleading information. The conversation highlights the importance of accurate charge values in electric field calculations.
mrshappy0
Two coaxial cylindrical conductors are shown in perspective and cross-section above. The inner cylinder has radius a = 2 cm, length L = 10 m and carries a total charge of Qinner = + 8 nC (1 nC = 10-9 C). The outer cylinder has an inner radius b = 6 cm, outer radius c = 7 cm, length L = 10 m and carries a total charge of Qouter = - 16 nC (1 nC = 10-9 C). What is Ex, the x-component of the electric field at point P which is located at the midpoint of the length of the cylinders at a distance r = 4 cm from the origin and makes an angle of 30o with the x-axis?
E∫dA=qenclosed
Okay so I found the charge per unit length (λ) which is Lguassσ. λ=0.8 nC. Then I performed the integral and solved for E to get E=qenclo/(2*Pi*ε*r*L). I wasn't sure how to get the x component though but figured it must be just E mag * Cos[theta] but this is wrong. Can anyone help me? I hope I showed enough work to get a response. I can double check my units and everything but I am pretty sure I converted everything to the proper units.
E∫dA=qenclosed
If ##\lambda## is charge per unit length, it should have units of C/m.
What values did you use in the formula?
Please post the figure the problem is referring to.
Opps I meant qenclosed =0.8nC
r=0.04m
1/(ε*Pi*2)=8.85*10^-12 N*m^2/C^2
L=10m
Is that what you really meant? ##\epsilon_0 = 8.85\times10^{-12}~\text{N m}^2\text{/C}^2## by itself.
1/(8.85*10^-12 (Pi)*2)=1.79836*10^10
Your work looks okay to me. What answer did you get?
35.8N/C but this is wrong...
Did you multiply by cos 30 since you only want the x-component?
Yes and still I had the wrong answer.
Well I multiplied 35.8 N/C by Cos(30deg)
What result did you get?
31.0028 n/c
It might just be rounding error or the number of significant figures. I get 31.1 N/C to three sig figs.
I actually entered the formula directly into the online homework thing. I just tried 31.1 N/C and still didn't work. I really dislike the way this homework is set up. Waste of time!
The OP needs to check his value for linear charge density; it could be that he's using a value that's 10x too small.
Yup, that's it. I grabbed 0.8 nC from one of your earlier posts, but the original problem said 8 nC.
Yeah thanks, I ended up figuring it out that it should be 8 not .8. This is very frusterating because the online homework assignment said that is was 0.8. So I wasted a lot of time due to that.
