Integrating Shell Collapse Velocity Equation for Free-Fall Time Calculation
  • Thread starter Thread starter TheTourist
    Hard Intergration
The discussion centers on deriving the free-fall time of a collapsing star using the shell collapse velocity equation. The equation provided is \(\frac{dr}{dt}=-[GM(\frac{1}{2}-\frac{1}{R})]^{1/2}\), and the user seeks to integrate it by substituting \(x=r/R\) to utilize a standard integral. There is confusion regarding the right-hand side of the equation, with concerns that it may not be correctly expressed as a function of \(r\). The conversation highlights the challenges in manipulating the equation for integration. Overall, the focus is on finding the correct approach to solve the integral for free-fall time.
TheTourist
I have derived the following equation for the velocity of a collapsing shell of a collapsing star.
\frac{dr}{dt}=-[GM(\frac{1}{2}-\frac{1}{R})]1/2
I now need to integrate this to find the free-fall time, and the hint is to manipulate the equation into a form where you can use a standard integral: substitute x=r/R and then use the standard integral \int[\frac{x}{1-x}]1/2 dx=\pi/2
I am completely stuck on how to do this
Hi TheTourist! :smile:
(have an integral: ∫ and a square-root: √ and a pi: π :wink:)
hmm … that RHS can't possibly be correct :redface:
shouldn't it be a function of r? :smile:
