Harmonic motion and acceleration
The discussion revolves around calculating the acceleration of a mass in simple harmonic motion with a frequency of 0.85 cycles per second, positioned 3.0 m from equilibrium. Participants suggest starting by writing the equation of motion and differentiating it twice to relate acceleration and position. There's a debate about whether sufficient information is provided, with some noting that dimensional analysis could help clarify the situation. The importance of assuming values for mass and amplitude is highlighted, as it may lead to consistent acceleration results regardless of specific parameters. Ultimately, the focus remains on deriving the acceleration based on the provided frequency and position.
Lacnez
A system exhibits simple harmonic motion with a frequency of 0.85 cycles per second. Calculate the acceleration experienced by the mass 3.0 m from the equilibrium
This question seems simple, I haven't really tried anything cause I can't figure out how to start.
I need help to start this problem off
You should write the equation of motion,differentiate twice with respect to time and try to eliminate time between acceleration and position and then set position equal to 3 m!
don't i lack the required information to use a motion equation
A quick test you can do is dimensional analysis. You are given a time and a distance, so in principle you might have enough information to calculate a velocity, or an acceleration, etc., but not, e.g. a force, since you are not given any quantities involving a mass dimension.
So, just go ahead and write out the equations. Maybe all the unknowns will disappear.
You could try to apply problem/puzzle logic.
Generally a question is asked when there is only one answer. Thus the answer you get if you assume the mass is 3 kg and maximum amplitude is 5.0 m will be the same as the answer when the mass is 1 kg and the maximum amplitude is 3.0 m
You could calculate both those answers, and if they are the same say "Wow; who would have thought!"
If the answers are different, you may then be able to do the "general" calculation to get the answer in terms of mass and maximum amplitude.
