Calculating Velocity in a Venturi Effect Nozzle: Converting Units
  • Thread starter Thread starter ISX
    Issues Units
The discussion centers on calculating the average velocity at the beginning and end of a Venturi effect nozzle with given dimensions and flow rate. The user initially struggles with unit conversions, questioning whether to convert measurements from centimeters to meters before performing calculations. The continuity formula and Bernoulli's equation are referenced, emphasizing the relationship between flow rate, area, and velocity. Participants clarify that both unit systems can be used as long as they are consistent, allowing for either cubic meters to be converted to cubic centimeters or vice versa. Ultimately, the user confirms their understanding and feels reassured about their calculations.
ISX
Venturi effect nozzle.. Starts off at 100cm and goes down to 40cm. The flow rate of the gas is 2.23 m3/s. What is the average velocity at the beginning and end of the nozzle.
Continuity Formula, Bernelli = Q = A1V1=A2V2
It's not the solution I am having trouble with so much, I am having a brain fart with units. I can take the area of 100cm and get 7850 cm2 and 40cm works out to 1256cm2 and you end up with a starting velocity of 0.000284 and an ending velocity of 0.001775 which I am assuming is cm/s.. Is that right or do I need to convert 100cm and 40cm to meters first and then do the calculation and then end up with meters/s?
Hi ISX. No need to assume anything here. If you carry your units along in the calculation it will guide you. You have V = Q/A. You plugged in numbers as V = (2.23 m3/s)/(7850 cm2). So, what do the units reduce to here?
I guess I've never read it like you put it, just always had a guide to follow in the book. I see cubic meters and cm squared so I woulda thought you would make them both cm or both meters..so I'm still not sure.
Right. You can go either way: convert the cm2 to m2 or convert the m3 to cm3.
Alright so both of these should be right then.
Yes. Nice. :smile:
Schweeeeet. Thanks.
