Hawking radiation, Is it possible?
In summary, according to Hawking radiation theory, black holes will eventually evaporate, giving off energy in the form of matter and radiation. This process also occurs during black hole creation. By creating and waiting for a black hole to evaporate, one can potentially create a perpetual motion machine. However, the energy source is the conversion of matter into energy and there is no violation of the law of conservation of energy. The process of Hawking radiation involves the conversion of virtual particle pairs, with one particle falling into the black hole and the other escaping, potentially decaying into other particles. The exact details of this process are still not fully understood.
Upisoft
350
According Hawking radiation theory the black holes eventually will evaporate. This process gives energy. The process of black hole creation also gives energy. The accelerating particles emit x-rays while falling into a black hole.
Now we can construct perpetuum mobile. We create a black hole, getting energy. We wait until it evaporates, also getting energy. We get evaporated matter and start from the beginning.
Where does all that energy come from? :eek:
Is the “Conservation of energy” law violated?
Astronomy news on Phys.org
The evaporated BH does not spew out matter but radiation.
There are just two sources of energy in your scenario, the gravitational binding energy of the mass as it forms into a BH and the conversion of that mass into energy via Hawking radiation and the final evaporation.
After that game over - nothing else.
No perpetual motion machine, sorry.
Garth
All you're talking about is the conversion of matter to energy. There is no conservation violated, because matter is lost in the evaporation of the black hole--that is where the energy of hawking radiation comes from.
So no.
Hawking radiation consists of both matter and radiation. As the black hole beomes very small, matter is increasingly important.
Regards,
George
So no.
OK, this sounds realistic, if we’re speaking about the energy. Now I have a problem to understand the process that creates photons out of quarks and leptons. And when this is supposed to happen? Immediately after crossing the event horizon or after some time, perhaps after hitting the singularity? :bugeye:
In normal space there are constantly quantum fluctuations in both the electromagnetic fields, and the ambient energy density. These fluctuations at any given time cancel each other out, more or less. We can visualize these fluctuations as the creation of virtual particle pairs-a particle, and an anti particle-that seperate, and then recombine, annihilating each other. In the presence of a black hole, it is possible that the anti particle may fall into the event horizon, reducing the mass of the black hole, while the particle is now free to escape (since it was always outside the event horizon), and decay into other particles.
This is my hand-waving explanation, as I don't know enough QM at that level to explain in any further detail.
I agree with George that Hawking radiation models include a matter component. I think he is also right about it becoming more important as black holes shrink, but, am admittedly a bit fuzzy about the details.
Regards,
George
I stand corrected :blushing: However the overall effect is to convert mass into energy.
Edit: Afterthought: Are not both particles and anti-particles radiated away from the BH? And if so would not these then self-annihilate leaving just radiation? However, I do understand that neutrinos are also radiated away.
Garth
This explanation is also problematic. Let’s suppose that virtual pair “neutron – antineutron” is created. Antineutron falls in the black hole and annihilates with neutron found there. This process should yield energy equivalent of twice the original black hole neutron mass. The other virtual neutron is outside the black hole. What is its speed? Obviously it has to move faster enough to overcome the gravity field of the black hole. This speed has to be near c, because otherwise it will eventually fall back into the black hole. So, we have 2 n mass equivalent inside the black hole and 1+ n mass equivalent outside the black hole. All we had before the process took place was 1 n inside the black hole.
:confused: :confused: :confused:
i think the particle-antiparticle pair that gets created out of vacuum has one of them at a positive energy and the other at negative so that the net energy is zero.
the antiparticle which falls into the black hole has the negative energy, and if it will encounter a particle with positive enrgy they will just cancel out with no photons emmited, so your antimatter would actually only take the mass while anihilating inside the black hole, and the net result is just a reduction of the BH's mass and a particle emmited away from the event horizon.
what i don't understand is why is it always the negative energy one that is falling into the BH?
the person who lectured on this radiation only said that the virtual particles are in a state of superposition, and when one of them falls into the BH it must be the negative enrgy one... but that's no explanation... i don't think he knows the answer.
Steve Carlip, a physicist at the University of California Davis, has written the best non-technical explanation that I have seen.
Regards,
George
As I said, it was a handwaving explanation, based on what I've been told. You can't do much with handwaving explanations with this kind of thing. And my knowledge of QM is not firm enough (basic wave mechanics only, definitely not QFT) to give any more detail.
Note that this doesn't work in the other direction -- you can't have the positive-energy particle cross the horizon and leaves the negative- energy particle stranded outside, since a negative-energy particle can't continue to exist outside the horizon for a time longer than h/E. So the black hole can lose energy to vacuum fluctuations, but it can't gain energy.
well, i guess id have to learn more GR and QED to understand it without just hearing - negative energy can't exist so that's the one whod fall into the black hole, that explanation doesn't satisfy me.
i got a friend who knows this stuff, and he said its just a fency mathematical trick, he wouldn't explain though, i don't have the propper knowledge yet.
Hiya
Hi guys,
Pardon me for being dense but as I understand it, energy and matter never go into the black hole. If they did then both would be destroyed by the singularity, that creates a paradox as 'matter & energy are not created or destroyed they are mearly transformed'.
This means that all matter & energy stay at the event horizon until the black hole evaporates...When this happens all the information that's been stored at the event horizon is emitted back into space.
Please correct me if I am wrong...It's been years since I dabbled last.
Frizz
Thats absolutely not true. Matter and energy falls into a black hole and joins the singularity and it is NOT destroyed. If this was true, and the mass/energy of a black hole was at the horizon, there would be no singularity as such at the center of the black hole, because from classical mechanics we know that inside a hallow sphere the gravitational field is zero. So this theory in itself creates a logical paradox.
Ooopz
Just made a terrible error. I just looked it up, you're quite right on most things...Only thing I would say is that no-one really knows what happens inside a black hole as the laws of physics break down. At the moment it's all speculation...That is until someone has the guts to venture inside:eek:
Not me though...:smile:
Thanks for correcting me.
We can't see inside a black hole, but that doesn't mean the laws of physics break down. We expect general relativity to be valid inside black holes (except perhaps in very strong fields), but I don't think we could ever make an observation to prove or disprove our models of the interior of a black hole.
But even then, only that person would know (if they survived). They couldn't communicate their observations to the outside world.
Yes I quite agree. Although there was a scientist some years ago (Cant remember his name) who sent a signal 4.2 times the speed of light across a small distance, I don't know if it was verified by other scientists...There are also jet streams emitted from some black holes that exceed the velocity of light...If this is true then communication would be possible inside a black hole, assuming you survived the tidal forces and being turned into spaghetti on the way through.
Frizz
You're probably talking about "superluminal motion", an effect in extragalactic radio jets that makes it appear as if they have transverse velocities faster than the speed of light. In reality, it's just another relativistic effect -- the jets aren't actually moving faster than the speed of light.
Yes, that's what I am talking about...For example, in M87 galaxy, the Hubble space telescope detected the jets moving at 6 times the velocity of light.
You're saying it's a reletavistic illusion yes? Can you explain how this works?
Well, sort of relativistic. One doesn't actually need to consider time dilation or length contraction to explain it.
The way we normally derive the transverse speed of objects is we look at how quickly they move from one angular position to the next. If we know the distance to the object, then we can multiply the rate of change in angular position by the distance to get a transverse speed. This works well for subrelativistic objects, but for highly relativistic ones, there's a complication.
Imagine a highly relativistic object (v ~ c) is coming toward us and emitting pulses of light at a steady rate. Since the object is moving toward us near the speed of light, it will be "keeping up" with the light pulses that it emits, which are coming toward us at the speed of light. If it were moving at exactly the speed of light (not actually possible), then both the object and all of the light pulses would be "on top" of one another and we would detect them all at the same time (in a burst of sorts). If the object is moving at slightly less than the speed of light, then the pulses would not be completely on top of one another, but the rate at which they reached our detector would be higher than the rate at which they were actually being emitted.*
Now imagine that, instead of an object moving directly toward us and pulsing, we have an object moving with a component toward us and a component transverse to us, emitting at a steady rate. As before, the object will be "catching up" with the light it emits, but it will also be moving to the side. Combine these two effects and you can get an apparent sideways motion that is greater than the speed of light.
* I'm working entirely within the rest frame, there's no need to consider the pulse rate in the frame of the moving object.
What is Hawking radiation?
Hawking radiation is a theoretical concept proposed by physicist Stephen Hawking in 1974. It suggests that black holes emit particles from their event horizon, resulting in a slow loss of mass and energy. This process is known as "evaporation" and is a fundamental principle in black hole thermodynamics.
Is Hawking radiation real?
While Hawking radiation has not yet been directly observed, it is considered to be a well-established concept in theoretical physics. Its existence is supported by mathematical equations and has been indirectly observed through various experiments and observations of black holes.
How does Hawking radiation affect black holes?
The emission of Hawking radiation causes black holes to slowly lose mass and energy over time. This process is incredibly slow for large black holes, but for smaller black holes, it can lead to their eventual evaporation. Hawking radiation can also have implications for the information paradox, as it suggests that information about objects that fall into a black hole may not be truly lost.
Can Hawking radiation be detected?
Due to its incredibly low intensity, Hawking radiation is extremely difficult to detect. However, some scientists believe that it may be possible to observe its effects through future experiments and observations, particularly in the study of black hole mergers.
Is Hawking radiation possible?
While Hawking radiation is still a theoretical concept, it is currently supported by mathematical equations and indirect observations. However, further research and experimentation are needed to fully understand its mechanisms and potential implications. Some scientists also propose alternative theories to explain the phenomenon of black hole evaporation.
  • Astronomy and Astrophysics
  • Cosmology
