Can Heat Flow from Cold to Hot?
Heat flow is defined as energy transfer rather than momentum transfer. In specific scenarios, such as oblique collisions, a faster molecule can gain kinetic energy from a slower molecule of the same mass. However, this interaction does not qualify as heat flow unless there is a net energy transfer among many molecules. The distinction between energy change and momentum change is crucial in understanding heat transfer dynamics. Overall, heat flow requires a collective transfer of energy rather than isolated interactions.
NicholasB54
If heat flow is the momentum change from a faster moving atom or molecule to a slower moving one, and momentum is mass x velocity is it possible - for a very limited amount - for heat to flow from a slower (colder) heavy atom to a faster moving (hotter) atom ?
Science news on Phys.org
(1) It's energy transfer, not momentum transfer, that's relevant.
(2) It is, I believe, possible in an oblique collision for a faster molecule to pick up speed (and hence KE) from a slower molecule of the same mass.
(3) But we wouldn't classify this as a flow of heat. To constitute a flow of heat we'd need a net transfer of energy for many molecules.
I was confusing energy change and momentum change alright
Thanks Philip
Thread 'Thermo Hydrodynamic Effect'
Vídeo: The footage was filmed in real time. The rotor takes advantage of the thermal agitation of the water. The agitation is uniform, so the resultant is zero. When the aluminum cylinders containing frozen water are immersed in the water, about 30% of their surface is in contact with the water, and the rest is thermally insulated by styrofoam. This creates an imbalance in the agitation: the cold side of the water "shrinks," so that the hot side pushes the cylinders toward the cold...
