Calculating Heat of Reaction: AgNO3 + HCL = AgCl + HNO3 | kcal/mole Formula
In summary, the given reaction liberates 699 kcal of heat when 2.10 g of AgNO3 reacts with HCL. To find the heat of reaction in terms of kcal/mole of AgNO3, a simple proportion can be used. By dividing (699 kcal / 2.10 g AgNO3) x (169.91 g AgNO3 / 1 mol AgNO3), the result is 56555.8 kcal/mole of AgNO3. Additionally, to find the heat of formation of AgNO3, the equation sum(moles x H of formation of products) - sum(moles x H of formation of reactants) can be used, with the data from a thermodynamic table
dg_5021
80
In the reaction shown below, 699 kcal of heat are liberated when 2.10 g of AgNO3 reacts with HCL:
AgNO3(aq) + HCL(aq) = AgCl(s) + HNO3(aq)
What is the heat of reaction in terms of kcal/mole of AgNO3?
How do u do this problem? Is there a formula for it?
Chemistry news on Phys.org
I am surprised how you didn't see this, but it's no problem since you try to learn something and asked this question.
Okay, 2.10 grams of AgNO3 give 699 kcal of thermal energy (heat), right? Then solve a simple proportion, like "2.10 grams give 699 kcal, then one mole of AgNO3 gives that". Remember that you can use 107.8, 14.0, and 16.0 g/mol for silver, nitrogen, and oxygen respectively, to find how many grams of AgNO3 are there in one mole of compound.
If there is another point you haven't understood yet, don't hesitate to ask.
Take care.
what i did was divide (699kcal /2.10g AgNo3) x (169.91 g AgNo3/ 1mol AgNo3) = 56555.8 kcal/mole of AgNo3
is this correct?
It seems to be correct. Unit analysis gives the same result.
thanks for the help
Do you mean what is the Heat of formation of AgNO3?
If this is the question then, turn 2.1 g of AgNO3 into moles. THen for the reaction, the the heat of the reaction is= sum(moles x H of formation of products)-sum(moles x H of formation of reactants). You should have a table of thermodynamic data in the back of you text with the heats of formation for everything except maybe AgNO3 which is what you are trying to find. You are given the heat of the reaction so just solve the equation for the heat of formation of AgNO3.
1. What is the purpose of calculating the heat of reaction?
The heat of reaction is a measure of the amount of heat released or absorbed during a chemical reaction. It is important for understanding the energy changes that occur during a reaction and can help predict the stability and feasibility of a reaction.
2. How do you calculate the heat of reaction?
The heat of reaction can be calculated by subtracting the enthalpy of the reactants from the enthalpy of the products. The enthalpy values can be found in a heat of formation table or can be measured using a calorimeter.
3. What is the kcal/mole formula used for in the calculation?
The kcal/mole formula is used to convert the enthalpy values from kilojoules per mole to kilocalories per mole. This conversion factor is necessary because enthalpy values are typically given in different units depending on the source.
4. Why is the heat of reaction typically reported in kilocalories per mole?
Kilocalories per mole is the standard unit for reporting heat of reaction because it is a more practical and relatable unit for chemical reactions. It allows us to easily compare the energy changes of different reactions.
5. How does the heat of reaction affect the rate of a reaction?
The heat of reaction can affect the rate of a reaction by influencing the activation energy needed for the reaction to occur. A higher heat of reaction typically means a lower activation energy, making the reaction occur faster. However, the reverse can also be true if the reaction is endothermic and requires heat energy to proceed.
  • Biology and Chemistry Homework Help
  • Thermodynamics
