Heat simulation in electrical/mechanical engineering
Simulation software is commonly used to address heat-related issues in electrical and mechanical engineering. The original poster is experiencing thermal cracks on alumina substrates during the firing and cooling processes and is seeking alternative simulation tools due to a lack of access to ANSYS Fluent. OpenFOAM is mentioned as a potential option for simulating these thermal issues. The discussion emphasizes the need for specific software recommendations tailored to the user's challenges. Overall, exploring various simulation tools can help in effectively managing heat-related problems in engineering applications.
Ash.K
Hi all,
I was wondering if anyone uses simulation software's to tackle the heat related issues in electrical/mechanical engineering?
Regards
Welcome to PF!
This question is very vague, so I would have to just answer yes. If you ask a more specific question, I may be able to provide a more specific answer.
russ_watters said:
Welcome to PF!
Hi Russ,
Thanks for your reply. I am having a lot of thermal cracks on alumina substrates during furnace firing/cooling of conductor/dielectric pastes. So, I wanted to know if there were any software's that could be used to simulate the issue. I have used ANSYS Fluent for simulation of wire annealing but since my company don't have a license for it, I was trying to learn if there are any other software's that can be used. i.e OpenFOAM?
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
