Heat with relation to work or energy
To determine the heat generated from a collision, one must calculate the kinetic energy (KE) lost during the impact. This involves finding the initial potential energy (PE) and the KE just before the collision, assuming that most of the lost energy converts to heat. When an object comes to rest after a fall, all mechanical energy is eventually transformed into random thermal energy, along with some energy potentially lost to sound and light. A good estimate for the heat produced can be obtained by equating the initial PE to the heat generated. This method provides a straightforward approach to understanding energy transformation in collisions.
aglo6509
Hello,
I know this seems silly to ask, but how could I figure out how much heat was given off when I know the force of an object hitting another?
Science news on Phys.org
What's important is how much macroscopic kinetic energy is 'lost' in the collision, not the force involved.
So if I know the KE of the system I can find the heat?
You need the amount of KE 'lost'. There are many kinds of energy other than 'heat' (random thermal energy), but you may be able to assume that most or all of the energy lost goes to 'heat'.
So if an object starts from rest 1/2 metre away from the object, I would first find Ug then KE right as it hits the object and assume all the lost energy is released as heat?
If you drop something and it comes to rest, all the mechanical energy (PE + KE) is lost. Some might go to sound and light, but sooner or later it all becomes random thermal motion somewhere.
Just set the initial PE (measured from the final position) equal to the 'heat' for a good estimate.
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
