Heat, Work & Internal Energy
In summary, to burn off 5.0 x 10-2 calories, a 59 kg woman would need to complete approximately 0.1752 sprints from rest to a speed of 4.5 m/s, assuming 100% efficiency in converting food energy to mechanical energy. This can be calculated by finding the kinetic energy of the sprinter and dividing it by the energy required to complete one sprint.
dnl65078
Please help with this problem!
How many sprints from rest to a speed of 4.5 m/s would a 59 kg woman have to complete in order to burn off 5.0 x 102 Calories? (Assume 100% efficiency in converting food energy to mechanical energy.)
Speed (v) = 4.5 m /s
==> h = v2 / 2g = (4.5)2 / ( 2 * 9.8) = 1.033 m
Mass (m) = 59 kg
Energy (E) = 5.0 * 10-2 cal = 5.0 * 10-2 cal * (1000 * 4.186) J
= 209.3 J
number of sprints is :
n = E / 2 m g h
= (20.9.3 J) / ( 2 * 59 * 9.8 * 1.033 )
= 0.1752 sprints
Have you tried calculating the kinetic energy the woman would have, converting it to calories, and finding the number of sprints? I'm not sure if that will get you the right answer, but I come up with about 3.5 sprints. You may want to check the back of the book to see if that is close.
Is the energy to be burned off 5.0x10+2 or 5.0x10-2 ?
Legion81 is correct, you'll need to figure out the kinetic energy of the sprinter.
What is the definition of heat?
Heat is a form of energy that is transferred between two systems or objects due to a temperature difference. It is measured in units of joules (J) in the International System of Units (SI).
What is the difference between heat and work?
Heat and work are both forms of energy, but they differ in how they are transferred. Heat is transferred due to a temperature difference, while work is done when a force is applied to an object and it moves in the same direction as the force.
How is internal energy related to heat and work?
Internal energy is the sum of the kinetic and potential energies of all the molecules in a system. It is affected by both heat and work, as they can change the speed and position of molecules, thus altering the internal energy of the system.
What is the first law of thermodynamics?
The first law of thermodynamics is the principle of conservation of energy, which states that energy cannot be created or destroyed, only transferred or converted from one form to another. This means that the total energy of a closed system remains constant.
How can heat and work be calculated?
Heat can be calculated using the formula Q = mcΔT, where Q is the amount of heat transferred, m is the mass of the object, c is the specific heat capacity, and ΔT is the change in temperature. Work can be calculated using the formula W = Fd, where W is the amount of work done, F is the force applied, and d is the distance the object moves in the direction of the force.
